Subject: Rotate a texture?
rreynolds opened this issue on May 14, 2005 ยท 6 posts
rreynolds posted Sat, 14 May 2005 at 12:17 PM
Is there a way to rotate a texture within Poser 5? I found a stack of dollar bills 3ds file and the landscape texture was applied in a portrait fashion. I rotated the texture, in an image editor, and it rendered fine, but I'm curious whether there's a method to do the rotation within Poser 5's MAT Room.
anxcon posted Sat, 14 May 2005 at 1:09 PM
offset U/V settings
danamongden posted Sat, 14 May 2005 at 1:17 PM
There was also a thread on this forum not too long ago where someone presented a rather complex shader that could do arbitrary 2D rotations of any texture, whether it started as a 2D image or the output from other shader nodes.
nruddock posted Sat, 14 May 2005 at 1:23 PM
Attached Link: http://www.renderosity.com/messages.ez?Form.ShowMessage=2135952
This is the thread you want.
rreynolds posted Sat, 14 May 2005 at 9:12 PM
I've saved the thread for future reference, but it's boggled my mind. For my immediate need, a 90 degree rotation in Irfanview did the trick.
Countach posted Sun, 15 May 2005 at 11:32 AM
You can export it as an .obj and arrange each bill to fit the texture you're using. It might be less of a hassle in the end.
