Subject: Possible to use a Freak Morph on M3? (Specifically the Reptile morph)
Furyofaseraph opened this issue on May 15, 2005 ยท 5 posts
Furyofaseraph posted Sun, 15 May 2005 at 6:37 AM
I want to use the HDReptile morph (that belongs to Freak) and use him on M3 - how can this be done, if at all.
Puntomaus posted Sun, 15 May 2005 at 7:03 AM
First you would have to add the channel to M3s Cr2. You can do that with MorphManager. Load M3 and the Freak and then look for the HDReptile channel in the Freaks Head and Neck, select it and copy it over to M3. Save M3 under a new name to not overwrite your original Cr2 and inject the HDReptile morph. The result might not be that cool as on the Freak and maybe it does not work well at all but it's worth a try.
Every organisation rests upon a mountain of secrets ~ Julian Assange
Furyofaseraph posted Sun, 15 May 2005 at 7:30 AM
Thanks I just tried it out, and not only did it work, it worked well. Thanks again ~Foas
Puntomaus posted Sun, 15 May 2005 at 10:49 AM
Yay, cool :-)
Casette posted Tue, 17 May 2005 at 2:01 PM
And ... it would work with other unimesh models? The Freak reptile morph into V3? I have injerted the SP3 nipples into Aiko3 and works nicely, but ... I dont know if the other is a very extreme surgery ...
CASETTE
