Onslow opened this issue on May 17, 2005 ยท 12 posts
Onslow posted Tue, 17 May 2005 at 3:18 AM
And every one said, 'If we only live,
We too will go to sea in a Sieve,---
To the hills of the Chankly Bore!'
Far and few, far and few, Are the lands where the Jumblies
live;
Their heads are green, and their hands are blue, And they went to
sea in a Sieve.
Edward Lear
http://www.nonsenselit.org/Lear/ns/jumblies.html
Onslow posted Tue, 17 May 2005 at 4:16 AM
If you are using a through the lens metered flash you can set the flash to fire either when the 1st curtain opens or when the 2nd curtain opens. Since the shutter will stay open until the sensor has sufficient light if you set it to fire with the first curtain, the 2nd curtain will close almost intaneously giving a sharp image. If you set it to fire as 2nd curtain the 1st curtain will open allowing light to the sensor, the flash will fire, the 2nd curtain will then operate. This gives a double image one for the first curtain opening and one for when the flash fired.
live;
sea in a Sieve.
Edward Lear
Onslow posted Tue, 17 May 2005 at 5:08 AM
ok - I have now learned how to spell instantaneously.
The above illustration is for a focal plane shutter, which is the most common type in use. By having a band of light crossing the sensor or film a very even exposure can be obtained, which would not be possible if all the sensor was exposed at once. For long shutter speeds the band is wide, for shorter shutter speeds the band gets narrower.
Message edited on: 05/17/2005 05:19
live;
sea in a Sieve.
Edward Lear
Michelle A. posted Tue, 17 May 2005 at 5:33 AM
Richard this is awesome! Thank you.....
I am, therefore I create.......
--- michelleamarante.com
patmartj posted Tue, 17 May 2005 at 7:03 AM
I second that! thanks Richard
tibet2004uk posted Tue, 17 May 2005 at 10:37 AM
WOW!! Thx for that Rich!!! It's clear and so easy to understand!!! U rock! Yep! ;D
TwoPynts posted Tue, 17 May 2005 at 10:59 AM
Rich, very interesting and informative. I appreciate the info.
cynlee posted Tue, 17 May 2005 at 11:07 AM
here, here!! thank you Richard :]
coolj001 posted Tue, 17 May 2005 at 7:43 PM
Fascinating stuff...thanks for posting. -Jeff :-)
mireille posted Tue, 17 May 2005 at 11:49 PM
HH.great explanations and diagrams! Thank,s a lot for that!
gradient posted Wed, 18 May 2005 at 2:41 AM
Excellent explanation! Further to this, please note that some DSLR's use a combination of mechanical and "electronic" shutter. For example ,the D70 I believe uses an electronic shutter for speeds faster than 1/250 second...mechanical for speeds lower than that. My understanding is that the electronic shutter is really only the time the sensor is "hot" and can accept data.
In youth, we learn....with age, we understand.
tvernuccio posted Wed, 18 May 2005 at 11:20 AM
you make it look simple, Richard. i don't understand metered flash. my manual doesn't mention it. i'll study this sometime. i'd like to learn more about it. thanks for doing this!
