Subject: I wonder about the propack
Marque opened this issue on Feb 04, 2001 ยท 5 posts
Marque posted Sun, 04 February 2001 at 8:59 PM
I know not everyone has two computers, and I notice that the propack looks for the poser you want to install to. I happen to have 4 instances of poser on this computer, just because I have four hard drives with poser on them so if I screw up I can just replace the whole poser 4 subdirectory. Now...what if you installed poser 4 on drive d: if you have a drive d: And say you go in under a different config, and if people on win98 need help I can help you set it up. So you have a different config, you install poser 4 on that config on drive c: Then you install the pro pack telling it to use the poser on drive c: Now you should (in theory) be able to go into the first config for regular poser 4 and use the second config for poser pro pack. Haven't tried it yet because I'm too busy to re-install everything, but I plan on checking it out. Does anyone think it's worth a shot? At least that way you could use the propack to create vanilla characters, and use the regular pack to do your morphs and stuffage. If I'm way off base just say so. 8^) Marque
