Subject: Does this happen to anyone? (memory bug?)
Talos opened this issue on May 18, 2005 ยท 4 posts
Talos posted Wed, 18 May 2005 at 1:22 AM
I will be retexturing a rather simple Victoria 2 (not even 3) figure (alone in a void, not even a scene), then do something as trivial as selecting a new eyebrow transparency when Poser 6 will ask me if I want to save the scene first (I think "Huh? Why? What?"), then the whole thing locks up, and I have to hit control/alt/delete to get out of the program and lose everything. Anything to do with the famous memory bug? I never got this in Poser 4. I guess it's a new case for "save early, save often".
DIMENSION_X posted Wed, 18 May 2005 at 6:24 AM
This is happening to me and a number of other artists with varying problems. This has been extensively documented on the forum's here. CL are in process of releasing SR1 update to resolve this issue
ggtonet posted Wed, 18 May 2005 at 6:26 AM
I had a similar problem in P4, maybe there's an imported figure that is corrupted...
jacksilverburgh posted Thu, 19 May 2005 at 4:44 AM
I had this problem with simple scene with V3. I wanted to save and some message showed up telling me I have to save,cause memory. So I did, but saved file was empty (0kb). I found out that Opera 8 was causing the problem. When it was shut down, Poser went ok even with the same scene...
