neoteric opened this issue on May 18, 2005 ยท 3 posts
neoteric posted Wed, 18 May 2005 at 3:52 PM
my assumption is they do not work together. Is this correct?
MrMongo posted Wed, 18 May 2005 at 4:20 PM
they're not quite the best pals you'd expect. Unfortunetly. However you can get positive results if you make sure that you disable the use external binary morph and the use compression options in the misc pref tab in the Poser Preferences. Also, if you use anything like WyrmMaster's Stand-Alone Dynamic Deformers, they will mess up the import of Poser files into Carrara, unless you want to have invisible people :D hth
Dave posted Fri, 20 May 2005 at 7:27 AM
Eovia is waiting on a SDK for P6 in order to make importing the new files better. David
