Silgrin opened this issue on May 20, 2005 ยท 10 posts
Silgrin posted Fri, 20 May 2005 at 2:46 AM
Silgrin posted Fri, 20 May 2005 at 2:48 AM
PS. I thought it wa s a problem with cube proportions, but the rendered tex seems somewheat repeatedly malformed, not just stretched. Also I tried several ways of mapping it, it should show if it was stretched, but the effect did not change at all.
Message edited on: 05/20/2005 02:49
criss posted Fri, 20 May 2005 at 5:19 PM
Check if the button "Map to Cube" is pressed.
nickcharles posted Sat, 21 May 2005 at 12:39 AM
Nick C. Sorbin
Staff Writer
Renderosity Magazine
"For every breath, for every day of living, this is my Thanksgiving."
-Don Henley
Silgrin posted Sun, 22 May 2005 at 7:47 AM
I tried these 4 mapping options as well as the size fields. I post here because it didn`t make any reasonable result. Looking fwd, Silgrin :/
Nicholas86 posted Mon, 13 June 2005 at 7:19 AM
Silgrin posted Mon, 13 June 2005 at 8:56 AM
It was a very flat cube. I think I used cubic mapping, so the axis shouldnt matter, I hope... Your cube is a bit strange. What did you do to it before texturing? It doesn
t look like Space->Add->Cube and then texturing. Maybe this STH is the key?
Nicholas86 posted Mon, 13 June 2005 at 9:13 PM
I just beveled and smoothed the cube. Nothing exciting. Brian
Silgrin posted Tue, 14 June 2005 at 2:45 AM
Smoothed or subdivided? When I smoothed objects, their edges remained sharp and only interior looked smooth.
Nicholas86 posted Tue, 14 June 2005 at 6:22 AM
Reread my post. I beveled the cube:) If you'd like send me the file you are having problems with to brian @ vizualds.com and I can fix it so you can inspect. Brian
