softcris opened this issue on May 23, 2005 ยท 12 posts
softcris posted Mon, 23 May 2005 at 5:55 AM
yes, i got already done the walk STEPHANIE in the texture i wanted and so...but now she should turn and slowing lay down and her body should turn into an object (a backspime already have the object in jpg.file)that is fixed in the background. So is a kind of Flash file in the end of the story..the thing is that I'm a dummy into those 2 operations: animation plus Flash. Please, fellows how do I do that? Using Poser Pro Pack (my favorite since I still not very friendly to Poser 6) Thanks for any help to solve that problem.
"'you shut up! or I'll
bring democracy to your country! "
Cris
Galvão aka Softcris - www.crisgalvao.com
(or softcris,
SoftCris)
Rendering since 1997 and
at Renderosity since 1999.
OS
Win 8.1 64 bit
nemirc posted Mon, 23 May 2005 at 1:57 PM
nemirc
Renderosity Magazine Staff Writer
https://renderositymagazine.com/users/nemirc
https://about.me/aris3d/
softcris posted Tue, 24 May 2005 at 4:05 PM
no! what is that?
Cris
(or softcris,
SoftCris)
OS
Win 8.1 64 bit
nemirc posted Wed, 25 May 2005 at 10:48 AM
nemirc
softcris posted Fri, 27 May 2005 at 3:41 AM
well...that is not very specific,right?could you be more into details in how to make this in Poser?thanks for helping
Cris
(or softcris,
SoftCris)
OS
Win 8.1 64 bit
nemirc posted Fri, 27 May 2005 at 12:51 PM
nemirc
nemirc posted Fri, 27 May 2005 at 12:57 PM
nemirc
dueyftw posted Sat, 28 May 2005 at 2:50 AM
Attached Link: http://www.lulu.com/content/68050#
My very first animation was an airplane taking off. I was done in Bryce, but It is a very good for someone who is starting to learn. Make a runway by stretching a black box. Find some simple Poser trees and buildings and place them so the camera has something in the background. Remember that if the camera doesn't see it then you are just adding to the rendering time. Not only should the airplane move and turn but the camera too. If you do this in Poser open the animation controls and edit in the airplanes roll. Have fun. Dalesoftcris posted Sun, 29 May 2005 at 9:24 AM
Cris
(or softcris,
SoftCris)
OS
Win 8.1 64 bit
softcris posted Sun, 29 May 2005 at 9:29 AM
Cris
(or softcris,
SoftCris)
OS
Win 8.1 64 bit
dueyftw posted Sun, 29 May 2005 at 10:59 AM
Look at stupid trick 1 on the other thread. Have her travel on the z axis into the spine object and past. If you are using Poser move the ground plane so she has something to hide behind once she is past the spine object. I would have her color also change to the white of the spine the moment she touches the spine. If you hide the spine behind the rotated ground plane and move it out at the same time that she goes behind it will appear that she turned into the spine. The only other way I can think of is to use a morphing program. Dale
softcris posted Mon, 30 May 2005 at 12:52 PM
ok Dale, seems perfect solution now I'll try until I got the best results..thanks very much..see you in few days..I guess..'not so sure I'll suceed but I will try to my best. THANKS!!!
Cris
(or softcris,
SoftCris)
OS
Win 8.1 64 bit
