isacatcar1 opened this issue on May 24, 2005 ยท 5 posts
isacatcar1 posted Tue, 24 May 2005 at 10:34 AM
Is any one using Injection Magic for their commercial products? And if you are what are your thoughts on it?
SamTherapy posted Tue, 24 May 2005 at 10:39 AM
I used it for one of mine, not currently on sale. It's easy to use but has a bug with the Pubic Hair morph. It would always default this to zero so I had to hand edit that part to get it to work properly. I use transmapped pubes rather than paint 'em on the skin, so it may not be a problem for most merchants. All in all, I like IM and I'll certainly keep using it.
lululee posted Tue, 24 May 2005 at 11:53 AM
I use it. It is very good but it can write some wonky code. I have never got any of my SP3 injects to pass testing. Most V3 stuff works fine but I always check it. Yes, I have reinstalled all the def files for SP3. It works fine on some computers but seems to fail with the testers. cheerio lululee
isacatcar1 posted Tue, 24 May 2005 at 2:21 PM
I am thinking of buying it. A bit expensive, but my understanding is that it is the easiest way to get custom morph to inject to a figure using a Morph Pose File. Have you all found it an easy application to use?
unzipped posted Tue, 24 May 2005 at 6:47 PM
Attached Link: http://home.online.no/~kjellil/
Poser's Little Helper
