magnus13 opened this issue on May 27, 2005 ยท 9 posts
magnus13 posted Fri, 27 May 2005 at 8:50 PM
Hi there, Is there a full list of all figures/props used in a scene anywhere? I've made a few things invisible & also others too small to see in the scene, so how can I view them again? Thanks. :) Michelle
mateo_sancarlos posted Fri, 27 May 2005 at 8:56 PM
Use the command "Show all figures".
magnus13 posted Fri, 27 May 2005 at 9:07 PM
Cool. Thanks mate.
wyrwulf posted Fri, 27 May 2005 at 9:52 PM
You can use the hierarchy editor to select and make things visible.
magnus13 posted Fri, 27 May 2005 at 10:39 PM
I tried the hierarchy editor before posting here thinking that would work, but it didn't. I clicked the eye next to the figure (?). I guess I did it wrong. Thanks though.
Fazzel posted Fri, 27 May 2005 at 10:40 PM
In fact the hierarchy editor is better because you can selectively make things visable again, in case you wanted to leave some things still invisable.
DCArt posted Fri, 27 May 2005 at 10:41 PM
magnus13 posted Fri, 27 May 2005 at 10:49 PM
Ahh... ok. Thanks.
GRiMAge posted Mon, 30 May 2005 at 8:13 PM
As for the small things, remember that you can select them from the drop down menus below the main window - figures on the left and bodyparts/props/lights on the right. If some prop has been parented to a figure you'll have to select the parent figure on the left to make it appear on the right. Hope this is useful. Grim
