dogor opened this issue on May 28, 2005 ยท 6 posts
dogor posted Sat, 28 May 2005 at 1:04 PM
judee3d posted Sat, 28 May 2005 at 2:23 PM
First thing to do is check for the latest updates on your Video card - even if it's new! Vid cards rarely have the latest when they first install. If that doesn't help, Hmm... how much poser stuff do you have, and is it all in the main Poser directory or do you have more than one runtime? If the Poser directory gets too full it could possible be slowing things down. What settings are you using for Firefly? I can't tell you which ones, but someone else can probably advise you that certain settings can cause problems. Have you tried rendering with the Poser4 Render Engine? It can be just as good as Firefly for simple scenes, and faster, less chance of locking up.
dlk30341 posted Sat, 28 May 2005 at 2:53 PM
Also, keep in mind 712 megs of RAM is really nothing. We have people here crashing Poser with 1-2gigs(some with more)of ram.
stallion posted Sat, 28 May 2005 at 3:38 PM
Have you installed poser sr-1 from e-frontier??
You might as well PAY attention, because you can't afford FREE speech
DIMENSION_X posted Sat, 28 May 2005 at 3:39 PM
Possible reason for the lock up while rendering if that is the problem I have found is a corrupted prop and texture map. To diagnose if this is the problem is to load each chartacter one at a time and the render it each time. I found this has helped me diagnose similar situations as to why Poser locks up while rendering.
If you experiencing this as a persistant problem you may need to ditch your excisting runtime library and re-install each item one at a time.
stewer posted Sun, 29 May 2005 at 8:11 AM
How many textures does your scene have and how big are they (in pixels, not kB)?
