shanes opened this issue on Feb 08, 2001 ยท 6 posts
shanes posted Thu, 08 February 2001 at 12:08 AM
Do the KTP plug-ins that are in Bryce 4 work as filters in Photoshop ? Thanks in advance.
EricofSD posted Thu, 08 February 2001 at 8:59 PM
As far as I know, they are the same. I have KPT 3.03 for Photoshop and use them in Bryce. Haven't looked to see if there is a KPT for Bryce, I just intermix the photoshop version. If you put the plugin in Bryce, you will either need to change your plugin directory in Photoshop or reload the plugin to the plugin directory in PShop. Or, you can get Plugin Commander and try to merge with that tool. I'm curious about how you work this out.
shanes posted Fri, 09 February 2001 at 9:47 AM
Actually what I am trying to do is use the KPT filters that are in Bryce to work as filters in Photoshop. I pretty much tried everything & it does not work, oh well. Thanks
jade_nyc posted Sat, 10 February 2001 at 10:35 AM
I think there is a way to do it shanes - give me a bit to dig through my stuff and see what I can come up with for you! Jade
nitreug posted Tue, 13 February 2001 at 8:05 PM
KPT filters run in many application, you just have to install them in as many directories. I got them in photoshop, as well in Ulead products and so on.
jade_nyc posted Tue, 13 February 2001 at 8:40 PM
okay shanes just transfer all the KPT 3 stuff to your photoshop plugins directory - then when you want to use them with Bryce again - just go to the Filters Tab - click on the downward pointing arrow and then click on Select plug-ins directory and browse to the directory where you moved the KPT 3 stuff. Hope this helps, Jade
