StealthWorks opened this issue on Jun 03, 2005 ยท 7 posts
StealthWorks posted Fri, 03 June 2005 at 6:02 AM
Hi, how can I render a wireframe image in Poser 6? In previous version you could render using the display settings but I can't figure out how to do this in P6. Also, I don't just want to export the image before rendering because the wireframe image needs to be much bigger than the screen so I'll need to do an actual render. Any help would be much appreciated Thanks in advance
ashish_s_india posted Fri, 03 June 2005 at 6:12 AM
use a UV Map template as texture and render. And same UV Map as transparency map. Will render to a wireframe :)
Mazak posted Fri, 03 June 2005 at 6:49 AM
maxxxmodelz posted Fri, 03 June 2005 at 6:52 AM
Just set your document display style to whatever "wire" style you want to render (ie., smooth lined, flat lined, lit wireframe, hidden line, or just wireframe), then set your render settings to "preview", with antialias checked, and then render the figure/scene.
Tools : 3dsmax 2015, Daz Studio 4.6, PoserPro 2012, Blender
v2.74
System: Pentium QuadCore i7, under Win 8, GeForce GTX 780 / 2GB
GPU.
Mazak posted Fri, 03 June 2005 at 6:52 AM
StealthWorks posted Fri, 03 June 2005 at 1:56 PM
thanks for the info - this is exactly what I was looking for. Mazak, thanks for taking the time to do those screenshots Cheers Mat
UVDan posted Mon, 06 June 2005 at 11:43 PM Forum Moderator
and I hereby proclaim you a Knight of the UV Empire!
Free men do not ask permission to bear
arms!!
