Forum: Vue
Subject: Infinite Terrain Altitudes?
lanaloe77 opened this issue on Jun 03, 2005 ยท 5 posts
lanaloe77 posted Fri, 03 June 2005 at 9:06 PM
There is a folder that comes with Vue5I that is called Infinite Terrain Altitudes. It has 3 selections in it that are used for procedural terrains. What are they for? When I try them they do nothing of interest. They are labeled Local Spikes, Simple Large Scale Fractal, and Variable Scale. I'm probably using them wrong. How are they suppose to be used?
dburdick posted Fri, 03 June 2005 at 10:28 PM
Probably to be used as a filter for driving procedural terrains.
lanaloe77 posted Sat, 04 June 2005 at 12:19 AM
I gather that but they don't work well or easily. Producing spikes is a given with the procedural terrains so why have a preset called Local Spikes? Does anyone use these presets with success?
Collateral_Damage posted Sat, 04 June 2005 at 7:16 AM
They are just functions for generating procedural terrains. If you are having problems with spikes chances are it is a scaling issue. Here you go... LOCAL SPIKES LocalSpikesTest.jpg SIMPLE LARGE SCALE FRAC SimpleLargeScaleFractalTest.jpg VARIABLE SCALE VariableScaleTest.jpg
lanaloe77 posted Sat, 04 June 2005 at 11:59 AM
Alright, thank you. Have you noticed that when scaling a procedural terrain by the corner handles that the height does not scale like a fractal terrain would? For a proc. terrain the numbers must be punched in for the terrain to scale correctly. What a strange occurence.
