Sadicus opened this issue on Jun 04, 2005 ยท 10 posts
Sadicus posted Sat, 04 June 2005 at 1:43 PM
Looking for tutorial on the best way to render layers in Bryce 5.5 example: Do you Turn off all the objects in the sceen, then render the background first, then turn off the BG, then render the objects in the sceen? I would like to have multiple layers to composite, like a color pass, shadow pass, Zdepth...ect. thanks!
RobertJ posted Sat, 04 June 2005 at 2:38 PM
o_O
Robert van der Veeke Basugasubasubasu Basugasubakuhaku Gasubakuhakuhaku!! "Better is the enemy of good enough." Dr. Mikoyan of the Mikoyan Gurevich Design Bureau.
RodsArt posted Sat, 04 June 2005 at 2:57 PM
___
Ockham's razor- It's that simple
RodsArt posted Sat, 04 June 2005 at 3:01 PM
Object masks do not recognize transparent objects, so at times you have to get creative and rebuild in the 2D enviroment.
___
lordstormdragon posted Sat, 04 June 2005 at 3:10 PM
Sadicus, Bryce won't do a true Z-depth. You can get close with "Distance Mask". Are you using Photoshop? You cannot do a shadow pass, or a color pass. You can isolate objects for masking using "Object Mask". You can isolate the sky, or run Depth-of-Field filtering, using Distance Mask and in PS, the "Select by Color Range" option. Show us a screenshot of your project and it will help us help you!
Sadicus posted Sat, 04 June 2005 at 3:58 PM
Incarnadine posted Sun, 05 June 2005 at 8:22 AM
Dang - AgentSmith's secret identity has been blown! (grin)
Pass no temptation lightly by, for one never knows when it may pass again!
Sadicus posted Sun, 05 June 2005 at 12:38 PM
uh...sorry it was posted in 3DW! :)
aprilgem posted Sun, 05 June 2005 at 9:37 PM
Attached Link: http://www.aprilgem.com/log/index.php?p=336
Yep, no shadow passes. The best way I've found to isolate shadows is to render everything untextured so you get the shadows on smooth gray surfaces. Then in Photoshop, you can sort of use what you've rendered as a "Multiply" layer -- with anything NOT the shadow(s) being masked out. So you know what I mean, I'm attaching a link to one of my WIP/tutorial pieces, where I rendered an untextured scene to help me add shadows to a scene. Hope it helps on the shadow part of your composite piece. Everyone else already answered the other parts.AgentSmith posted Sun, 05 June 2005 at 10:13 PM
Rofl....that shocked the heck outta me...scanning this thread just to see my full, real name... AgentSmith
Contact Me | Gallery |
Freestuff | IMDB
Credits | Personal
Site
"I want to be what I was
