Subject: I found a bug in Poser 6.
akura_ opened this issue on Jun 04, 2005 ยท 9 posts
akura_ posted Sat, 04 June 2005 at 3:28 PM
Maybe no one used it or noticed it, but if you use the reset button on the diles, sometimes, it stops working. And I also notice at one point that I was no longer able to change the values that I typed in. Even after typing in zero, it went back to the preview value. These bugs were found after using the parameters.
Sivana posted Sat, 04 June 2005 at 4:07 PM
Poser 6 got a big update last week. Do you already have it?
Ben_Dover posted Sat, 04 June 2005 at 4:09 PM
Have you rebooted and tried to recreate the problem? Just curious. :)
Fazzel posted Sat, 04 June 2005 at 4:09 PM
Add it too the list. :o) As for the dial going back to the preset value, that isn't really a bug. Sometimes the dial has a fixed value. Also if you lock your figure, then the dials won't change until you unlock your figure again.
ynsaen posted Sat, 04 June 2005 at 9:03 PM
just for clarification.
Rendy posted Sun, 05 June 2005 at 7:51 AM
#2, isn't it that bug update that's causing this problem?
ARCHITECT posted Sun, 05 June 2005 at 10:53 AM
...same here. I have discovered that some morphs disappear if you have rendered a scene, saved it as a pz3, then - later - re-open the scene... If you look for them you will find all the dials for the morphs... e.g. "open mouth" is set to 1.0 but the mouth of that figure is closed. Nothing happens at 1.0, at 0.0 and back again to 1.0. The only workaround for me - to delete that special morph and to "install" it once again. A.
Solo761 posted Sun, 05 June 2005 at 12:07 PM
I had that problem too. I found that PMD files were to blame, ie. that new way of saveing scenes taht saves morphs in PMD files. When I disabled that morphs stayed.
JusCase posted Sun, 05 June 2005 at 10:06 PM
Here's another one: Start any render, preferably one that takes a few seconds so you can see this in action. Then hit escape. The render progress box, along with the 'cancel' button, will dissappear, but the rendering process will continue.
