DrowVampyre opened this issue on Jun 06, 2005 ยท 4 posts
DrowVampyre posted Mon, 06 June 2005 at 3:23 AM
Hi all. I've been having a rather strange problem recently. I can work in a scene all I want, and things work just fine. But when I save a scene and come back to it later, after exiting Poser, the expression I have on V3 is gone. Her pose is the same, and all the other stuff is stilol htere just fine, but she's got that blank expression. Does anyone know how to fix this? I'm using POser 6 SR1, and it's only been doing this recently...
FreeBass posted Mon, 06 June 2005 at 4:39 AM
Dunno the cause, but a quick fix would be to save yr expression as a .fc2 once ya have it "perfect". This way ya can also use it later w/o havin' to extract it from yr pz3.
WARNING!
This user has been known to swear. A LOT!
TrekkieGrrrl posted Tue, 07 June 2005 at 5:20 AM
Have you by any chance set P6 up to use external pose files (it's on by default and I can't remember the exact name of it duh) If you do that and move the PZ3 from wherever the pose files are, you'll get no morphs on the loaded PZ3. Took me a while and a lot of wondering as to WHY! I always save my pz3's to desktop while I'm working on them, then when the pic is done I move them to the archive folder. But I had to switch off the external morph thingie to do that. Apparently it doesnt' even help to move the pose files to the same (new) spot as the PZ3 is, it seems to be hardcoded with exact path into the PZ3... :o(
DrowVampyre posted Tue, 07 June 2005 at 5:36 AM
Hmm, I didn't change that setting, but I haven't moved the files either. I keep them all in the same folder as always, a seperate "Scenes" folder in the P6 directory.
