Forum: Bryce
Subject: Unable to import OBJ files...........again & again & again.
marcfx opened this issue on Jun 07, 2005 ยท 9 posts
marcfx posted Tue, 07 June 2005 at 11:51 AM
Really getting Pid off with Bryce 5.5.....I keep getting the wonderful 'ERROR' messages when trying all sorts of ways to import 'Obj' & Obp' files. When viewing the 'Files of type' the 'objects (.obp)' shows nothing in my folder. When viewing the 'Files of type' the 'Bryce2 objects (.obj)' shows all my files in the selected folder. Its when I select one of the files I get the error message below: When going to 'Create' - 'Import' I get an error message saying "An unexpected error has occurred (invalid format)". When viewing the 'Files of type' the 'All files (.*)' I get the 'mtl' File shown too but still has the error message appear. ------------------------- All works OK in Bryce 5!!!..........Bryce 5.5 = $99 for hassle! ------------------------------------ PART 2............. "Bryce 5.5:Bryce55.exe - Unable to locate DLL" The error message: "The dynamic link library B5Axiom.dll could not be found in the specified path D:Program FilesDAZBryce 5.5;,;C:WINNTsystem32;C:WINNTsystem;C:WINNT;C:WINNTsystem32;C:WINNT;C:WINNTSystem32Wbem;C:Program FilesCommon FilesAutodesk Shared;C:Program Filesbackburner 2;C:WINDOWS;C:WINDOWSCOMMAND". Then the folder opens to show NO files at all. Is this because of the import DLL missing? All can be imported into Bryce5 OK.?????????? Any wise and wonderful people out there know of a solution?
Smile, your dead a long time :)
foleypro posted Tue, 07 June 2005 at 12:44 PM
Hmmm... What Operateing System are you running...? If its Windo$e98 or 98SE your out of Luck...
danamo posted Tue, 07 June 2005 at 12:50 PM
Sorry Marc, I haven't upgraded yet so I haven't run into this problem. I know you know how to import models, so I won't give you redundant advice on how to import stuff into Bryce5,lol. Do you still have your old Bryce5 installed? If so, could you import the models into a default Bryce5 scene(save it) and then open and convert the file into Bryce 5.5? I know this might be an added hassle, especially if you're importing a Daz, or Poser figure, but it's all i could think up off the top of my head. Good luck.
Erlik posted Tue, 07 June 2005 at 1:05 PM
Bryce 5.5 apparently has issues with unmapped OBJs or the ones with "out of range" data. Mine simply won't import them. Try running them through UVMapper. BTW, B55Axiom.dll is located in the Bryce folder, Program FilesDAZBryce 5.5. It might have been damaged or it simply disappeared. Even stranger things have happened under Windows. :-) The ultimate attempt to fix the things is a reinstall of 5.5. After a complete removal, not just over the old installation. PS. And it seems strange to me that Bryce is looking for its own DLL in max folders.
Message edited on: 06/07/2005 13:06
-- erlik
marcfx posted Tue, 07 June 2005 at 1:07 PM
@foleypro. Its 2000 SP 4. @danamo. Yes i have Bryce 5 and I've been doing just that but its very annoying after paying out for Bryce 5.5. What bugs me is that the file not found by Bryce 5.5 is a Bryce 5 dll file (B5Axiom.dll). I even copied the file to Bryce 5.5 and i didnt get the error message (The dynamic link library B5Axiom.dll bla bla bla) but it crashed instead!!
marcfx posted Tue, 07 June 2005 at 1:12 PM
@Erlik No, its not the B55Axiom.dll its asking for the B5Axiom.dll file. The B55Axiom.dll is in the Bryce folder.
dan whiteside posted Tue, 07 June 2005 at 1:18 PM
Also .OBJs that have values with exponents won't load in 5.5. This is pretty common with pro modelers and they also worksin 501. I know you just want 5.5 to work correctly (I do too!) but UVMapper does fix all the .obj problems I've found but you can also (well almost always) load into 501 and save, and load that into 5.5. Here's looking forward to another 5.5 update; Dan
marcfx posted Tue, 07 June 2005 at 1:28 PM
Thanks Dan. I'm not that gened up on UVMapper and wouldnt know where to start and as i said to danamo, thats what I'm using to do import (501) the obj files.........hurry up 5.5.5!!
marcfx posted Tue, 07 June 2005 at 2:31 PM
Message from Daz......dowloaded and reinstalled bryce 5.5a and problem seems to have been cured. Thanks you guys, appreciated the help.
