Forum: Vue
Subject: Newbie 101 - Objects and Plants in Infinite?
Dragontales opened this issue on Jun 07, 2005 ยท 7 posts
Dragontales posted Tue, 07 June 2005 at 2:02 PM
I noticed in some of the ecosystems that it is using objects and some plants that I don't have in my object and plant directories. Ie, some cars, etc. Does Vue 5 infinite come with more plants and objects than esprit? If so, where do I find them? Do they need to be installed seperately? So far my directories, (plants, objects, functions, materials, etc) all are identical to esprit with the only acception being the ecosystems. Thanks Dragontales
wabe posted Tue, 07 June 2005 at 2:41 PM
Of course you can always import elements - objects, plants etc. There are some excellent plants from dreampaint available for free. Maybe you look for them - for example here in free stuff.
agiel posted Tue, 07 June 2005 at 3:03 PM
Try the Free Stuff link in the header of the forum, not the link all the way at the top of this page. That will take you to the Vue Free Stuff.
Dragontales posted Tue, 07 June 2005 at 4:08 PM
Thanks for the info. I'll definately check the link out. I was more referring to whether or not Infinite came with more things than esprit did. Some of the ecosystems are using items that are not in my menu's, but are loading fine. I'd like to know where they are coming from. Thanks, Dragontales
spider1313 posted Tue, 07 June 2005 at 4:27 PM
No, Dragontales...the plant library in Infinite is the same as Esprit(I believe all the way back to Vue4). However, a lot of the plants that you are seeing in Vue renders are from the great collection of packages at RDNA which have been run through Poser, imported into Vue, and then converted to .vob's...making them eco-able. steve
lanaloe77 posted Tue, 07 June 2005 at 5:11 PM
I too have noticed this: preset ecosystems that come with vue have objects that are not in the libraries so they can't be used as individual objects conventionally but can be used as ecosystems. So where are these objects located in the vue directories or are they only imbedded into preset ecosystems?
lingrif posted Tue, 07 June 2005 at 6:23 PM
Some I have not found in the Vue directories. I looked for a way to save the object from the eco system, but I don't think it's possible. Maybe someone figured out a way?
www.lingriffin.com
