Subject: IBL and Hair (P6)
Robo2010 opened this issue on Jun 10, 2005 ยท 2 posts
Robo2010 posted Fri, 10 June 2005 at 1:18 AM
Since SR1 came out, I been really busy in Poser6, and Wings3D. So when I like to take a break, I tend to play with the lights. I am impressed with the new lighting in P6. So, today playing with IBL's, their is a lot to learn. I mean a lot. Not that basic, even using characters like V3 with textures. Then lighting in the material Room (Contrast, color, resolution..etc), then light properties in the pose room (Map size, shadow, AO strength, Raytrace...etc). Then if you add one more light and make it infinite, position it (behind, side top (L/R). Do a render..then to bright, or dark. You have to go through procedures again, and check which one is in need of changing, or delete or add another. All has to balance out. So, tonight made this sample to get me through and I found a new problem. The "hair". If you look at the top of her hair where it is parted, she is sorta losing hair. Can see her scalp. You add one more IBL, it gets worse. Why another IBL..I dunno. So I deleted it.
Robo2010 posted Fri, 10 June 2005 at 1:19 AM
Now, that was Kozaburo hair from Character. I go to hair folder and load up Grace Lion Hair. I get this. What I am doing wrong? Other than being tired, and losing my mind. Had a real busy day today. :-)
Message edited on: 06/10/2005 01:25
