tedbragg opened this issue on Jun 10, 2005 ยท 8 posts
tedbragg posted Fri, 10 June 2005 at 9:38 AM
randym77 posted Fri, 10 June 2005 at 10:05 AM
Have you thought of using a transparency map on one of BVH's bustiers? Looks like you have the skill to paint your own textures. :-)
tedbragg posted Fri, 10 June 2005 at 10:24 AM
Trans map? Hmmm. Would I make one of those using the regular tex-map templates? One thing I didn't like about BVH's warrior princess bustier-- they never seemed to use the V2 morphs properly and it fit bulky. He's made his own female figure and designed the suits around her, so...I don't know. What else can I do for this? Other ideas?
bjbrown posted Fri, 10 June 2005 at 11:12 AM
Use the regular tex-map templates to make a transparency map, and just use black, white, and gray to set up your invisible and transparent areas. There are also programs that will add V2 morphs into V2 clothes. Tailor is one, I also just bought Clothes Converter but I haven't really learned how to use it yet. There are others. There are also magnet sets available to shape V2 clothes. You could take any V2 bustier- such as one from a lingerie set- and as long as you like the shape, you can transform it into armor. Make a custom texture and use spectacular settings and reflection maps to make it look like metal rather than cloth.
randym77 posted Fri, 10 June 2005 at 11:20 AM
Yes, to make a transmap, you use the same templates. Only you only use two colors, black and white.
I don't own V2, but I'm sure there must be other skimpy armor out there for her. Have you looked at RDNA? They've got a lot of armor pieces there, free and for sale.
Another possibility would be to use V1 stuff, and add the V2 morphs you need yourself. Either with the Tailor, or using magnets.
tedbragg posted Fri, 10 June 2005 at 1:51 PM
Wish I knew how to make clothes and stuff for Vicky...Mike...shoot, knew how to PERIOD. I blew hours searching for what I wanted, but no dice. Looks like I'll be painting her gear on instead. Do any of the modelers take requests?
miked123 posted Fri, 10 June 2005 at 2:10 PM
Attached Link: http://www.xurge3d.com/inc/pdetail?v=1&pid=133
Try this link. It an outfit for V3 that matchs pretty well. Xurge3D makes very good stuff.randym77 posted Fri, 10 June 2005 at 2:50 PM
I think the problem he's running into is that his character is a V2 character - uses the V2 morphs. There's a lot more stuff for V1 and V3 than for V2.
I must say, though, that's a terrific outfit. I think Xurge is the best armor maker in Poserdom.
