Subject: OBJ export problem in P6.
Torulf opened this issue on Jun 11, 2005 ยท 7 posts
Torulf posted Sat, 11 June 2005 at 3:43 PM
I have Poser 6 and SR1. I want to export an OBJ file but after I made the usual popups the poser does nothing. It is not possible to do anything after that so I have to exit it. Poser must have crash. Has somebody else the same problem? How to solve it? I have not had any more problems with P6.
TG
Fazzel posted Sat, 11 June 2005 at 4:05 PM
Kind of depends on what you are trying to export. Are you trying to export an entire scene or just a morph target or a small object. If you are trying to export an entire huge scene filled with a lot of characters, props, clothes, and hair, then no wonder it is bogging down. If you are just trying to export something small then it sounds like you really do have a problem, because I can export a body part like a head with no problem.
Torulf posted Sat, 11 June 2005 at 4:29 PM
Its a scene I want to export. Not a big one but soon I have to export big, komplex scenes. Are this problem komon? Are there any methods to go round the problem? This was not a problem in P5.
Message edited on: 06/11/2005 16:30
TG
Fazzel posted Sat, 11 June 2005 at 5:43 PM
Probably then what's happending isn't that Poser is locking up, but rather just having to work a long time to export the whole scene. Have you tried leaving it alone for a few hours to see that it eventaully exports the scene? If it is complex enough you might have to leave it overnight. Just out of curiousity, what are you going to do with this object file once you export it out of Poser? Perhaps an alternative would be to export small parts of the scene and then recombine them in the program you are going to use to import the objects.
Torulf posted Sat, 11 June 2005 at 6:17 PM
Im going to import it to Cinema4d true InterPoser. Its a test now but in future I want to import animations. For this IterPoser its necessary to export objets not as parts. Is this a bug? It must be. Hop it will be fixed in SR2.
TG
Robo2010 posted Sat, 11 June 2005 at 7:06 PM
I haven't had any problems exporting. In this image I made the Barrier Wall (Along with other meshes. But the wall is the one I was working on this week.) in Wings3D, then imported into poser, Grouped, then exported it out of Poser. Then UVmapped, then imported back into Poser. I am using P6 with the patch.
Message edited on: 06/11/2005 19:06
UrbanChilli posted Sat, 11 June 2005 at 9:35 PM
I have had the same problems, trying to export at piece of cloth as obj to UV mapper. Though I never had problems with exporting a full scene. When that happens all I can do, is shut down Poser, open again and try to export again. Some times it takes 3 try before it's exporting.
