Ken _Gilliland opened this issue on Jun 16, 2005 ยท 3 posts
Ken _Gilliland posted Thu, 16 June 2005 at 12:53 PM
With Poser 5 and 6 not wanting to attach P4/PP MAT bump files I thought the easiest solution would be to write a partial MAT file using the Bump part of the shader tree... the problem I'm having is it wipes out the exisiting texture map as well.
Below is a portion of the code, what am I doing wrong?
version
number 5
figure
material plumage
bumpStrength 1
bumpMap ":Runtime:textures:songbirds:SBRP5_bump.jpg"
0 0
shaderTree
node "poser" "PoserSurface"
pos 10 10
nodeInput "Bump"
value 0.036 -10 10
parmR NO_PARM
parmG NO_PARM
parmB NO_PARM
node "Image_Map_4"
file ""
node "image_map" "Image_Map_4"
pos 291 277
nodeInput "Image_Source"
value 1 1 1
parmR NO_PARM
parmG NO_PARM
parmB NO_PARM
node NO_NODE
file ":Runtime:textures:songbirds:SBRP5_bump.jpg"
nodeInput "Auto_Fit"
value 0 0 0
parmR NO_PARM
parmG NO_PARM
parmB NO_PARM
node NO_NODE
file ""
nodeInput "U_Scale"
value 1 -1 1
parmR NO_PARM
parmG NO_PARM
parmB NO_PARM
node NO_NODE
file ""
nodeInput "V_Scale"
value 1 -1 1
parmR NO_PARM
parmG NO_PARM
parmB NO_PARM
node NO_NODE
file ""
nodeInput "U_Offset"
value 0 0 1
parmR NO_PARM
parmG NO_PARM
parmB NO_PARM
node NO_NODE
file ""
nodeInput "V_Offset"
value 0 0 1
parmR NO_PARM
parmG NO_PARM
parmB NO_PARM
node NO_NODE
file ""
nodeInput "Texture_Coords"
value 1 0 0
parmR NO_PARM
parmG NO_PARM
parmB NO_PARM
node NO_NODE
file ""
nodeInput "Image_Mapped"
value 4 0 0
parmR NO_PARM
parmG NO_PARM
parmB NO_PARM
node NO_NODE
file ""
nodeInput "Background"
value 1 1 1
parmR NO_PARM
parmG NO_PARM
parmB NO_PARM
node NO_NODE
file ""
nodeInput "Global_Coordinates"
value 0 0 1
parmR NO_PARM
parmG NO_PARM
parmB NO_PARM
node NO_NODE
file ""
nodeInput "Mirror_U"
value 0 0 0
parmR NO_PARM
parmG NO_PARM
parmB NO_PARM
node NO_NODE
file ""
nodeInput "Mirror_V"
value 0 0 0
parmR NO_PARM
parmG NO_PARM
parmB NO_PARM
node NO_NODE
file ""
nodeInput "Texture_Strength"
value 1 0 1
parmR NO_PARM
parmG NO_PARM
parmB NO_PARM
node NO_NODE
file ""
nruddock posted Thu, 16 June 2005 at 2:05 PM
Partial MATs don't work, you have to include the whole Shader tree.
For P5, there is no alternative.
For P6, you can use a Wacro do modifications to the Shader tree.
Ken _Gilliland posted Thu, 16 June 2005 at 2:11 PM
Ugh... I was afraid that was the answer...
