Mec4D opened this issue on Jun 16, 2005 ยท 100 posts
Mec4D posted Thu, 16 June 2005 at 7:19 PM
Attached Link: |||||||||| Mec4D Media Room |||||||||| Under Construction ||||||||||
Here is my next mini experiment and it works fantastic I will be very happy to use here an environment but most poser users use images so this time something for everyone. It take very fast and with couple of clicks your scene is ready, don't look at the ground textures it was just to catch the mood. I used for the test panoramic skies free from : http://sentos.visualthoughts.com/skies/ you can download the same if you wish to play with this mini tutorials at home. The all settings of the light are very important and I tested it from the begining we got poser6. Poser6 light setting used above is based on my own mini experiments and tests. About 2 weeks I go to start with new HDRI Project for Poser6 it will a very interesting Photo outdoor documentary so please check out my new Media ROOM section on my web, there I will from now upload all info, tests, experiments, tutorials, projects and freebies and everything only for Poser6 and some for Poser5 users. Thank you for your attention Hugs! Cath_________________________________________________________
"Surrender to what it is - Let go of what was - Have faith in what will be "
face_off posted Thu, 16 June 2005 at 7:33 PM
Cath, you need to mirror the background image you cut from the IBL image - otherwise it won't match the IBL lighting. What method are you using to position the Specular Diffuse Sun?
Creator of PoserPhysics
Creator
of OctaneRender
for Poser
Blog
Facebook
Mec4D posted Thu, 16 June 2005 at 7:42 PM
Mec4D posted Thu, 16 June 2005 at 7:46 PM
face_off posted Thu, 16 June 2005 at 8:06 PM
Attached Link: http://www.renderosity.com/messages.ez?ForumID=12356&Form.ShowMessage=2197864
Cath, you should know by now that I always do my homework "good"! Your lightprobe layout is different to the others that have been posted on this forum - check Nerd3d's image at the above link - your green "scene centre" represents the "bottom" of the scene in Nerd's graphic. Regardless of this, you are using the FRONT of the IBL image as the BACKground. Which means you need to rotate the IBL image 180 degrees in the Y Axis, and flip the background image. Otherwise your IBL lighting is 180 degrees out from the background image. For example, if you have an IBL with a very bright FRONT (say, the sun), and dark LEFT, RIGHT and REAR, when you cut out your background, you are getting the bright FRONT (which will mean the sun will be appearing in the background), but when you render with the IBL image, the front of your scene will be brightly lit from the IBL image (the sun), but the back of your scene will be showing the sun! So it will opposite to matching. That's why I put together the python script - to fix all this up and get it all matching. So your tutorial works for very evenly lit IBL images, but not for images that have variation in them.Creator of PoserPhysics
Creator
of OctaneRender
for Poser
Blog
Facebook
Mec4D posted Thu, 16 June 2005 at 8:07 PM
PapaBlueMarlin posted Thu, 16 June 2005 at 8:12 PM
I'll have to try this out sometime this weekend. Thanks for your brillant ideas Cath :) The site is looking really good too :)
Mec4D posted Thu, 16 June 2005 at 8:28 PM
Paul Wrote: Regardless of this, you are using the FRONT of the IBL image as the BACKground. Which means you need to rotate the IBL image 180 degrees in the Y Axis, and flip the background image. Otherwise your IBL lighting is 180 degrees out from the background image No you don't have to flip anything, because I used panoramic image for that and created from that Angular maps and nothing have to be rotated, the light in the venus render come from behind the model as it was in the reality, the ::front:: name is used for the VIEW of the scene not for the light direction. Please wait I am not finished with everything yet. This correct methode allow you to create panoramic images in Bryce or Vue and import the light to Poser6 :) tip for the day! This above version is used for almost every software that use HDRI and IBL ;)..... Thank you Jeremy, I am happy you like my new Room on my website.
pokeydots posted Thu, 16 June 2005 at 8:34 PM
BookMark :O) This looks very interesting Cath!
Poser 9 SR3 and 8 sr3
Processor Type: AMD Phenom II 830 Quad-Core
2.80GHz, 4000MHz System Bus, 2MB L2 Cache + 6MB Shared L3 Cache
Hard Drive Size: 1TB
Processor - Clock Speed: 2.8 GHz
Operating System: Windows 7 Home Premium 64-bit
Graphics Type: ATI Radeon HD 4200
•ATI Radeon HD 4200 integrated graphics
System Ram: 8GB
face_off posted Thu, 16 June 2005 at 9:00 PM
Cath, that cloud that you've pulled out of the Lat/Long map as the BACKGROUND is actually what is illuminating the FRONT of the venus statue. So the lighting needs to be rotated 180 degrees, and the background image flipped.
Creator
of OctaneRender
for Poser
Blog
Facebook
yelocloud posted Thu, 16 June 2005 at 9:03 PM
Very interesting info Cath indeed. & I love the look & feel of the Media Room, I want to test out some things based on this info & add my $.02 over the weekend. Cheers
Mec4D posted Thu, 16 June 2005 at 9:06 PM
Mec4D posted Thu, 16 June 2005 at 9:21 PM
Message edited on: 06/16/2005 21:22
face_off posted Thu, 16 June 2005 at 9:34 PM
Message edited on: 06/16/2005 21:35
Creator
of OctaneRender
for Poser
Blog
Facebook
Mec4D posted Thu, 16 June 2005 at 9:50 PM
face_off posted Thu, 16 June 2005 at 11:46 PM
and what you used for Angular map?
Your tutorial makes no reference to an Angular Map! I am following the steps in the tutorial. Are there other steps in there that are missing?
***and as always you without to try it really out and stay close to the parameters know better, if this everything I say is boll, then the rest of the HDRI too.
I'm not absolutely certain what you are saying here Cath, but for testing, I try and break it down into small pieces, so that at each step I know if something works, or it doesn't work. By using a complex IBL image (such as the sky map you used above), it's difficult to see what effect the IBL light is having, so I went for something simple - a white blob IBL image - which clearly illustrates the issue. With a white blob on the IBL image, the lighting is from the front, whilst the background shows the lighting from the rear - which is not consistent.
Creator
of OctaneRender
for Poser
Blog
Facebook
face_off posted Fri, 17 June 2005 at 12:00 AM
Creator
of OctaneRender
for Poser
Blog
Facebook
ashish_s_india posted Fri, 17 June 2005 at 12:15 AM
Face_off's right. Once Again!
Mec4D posted Fri, 17 June 2005 at 12:38 AM
I think you are are kidding here , the whole tutorial is based on Angular map with other words Lightprobe and you can see this from the first line in the first post. and what have to do the images you posted? I have not idea. If you converted mirrorball to Angular map and you think it is fine then much success.. One more time before I kill myself: You have to create Angular Map |LightProbe with Aspect ratio: 1:1 using Latitude panoramic image with the Aspect ratio: 2:1 and nothing else. What I can tell you more? you need maybe more imagination to understand the graphics because I can't write it down for you. Post number 3 will tell you everything you need to know, and one more time a FRONT is a front of the scene as the computer monitor is in the front of you. I don't wrote in the in post number 3 :: of the scene. I was for plan to finish about the sun light and other things but it make not sense anymore this topic is killed already again. I will upload everything again to my new Media Room so everyone please check out the whole finished story one more time . I will maybe use my own material so you will get the chance to download and use the same materials to get the same effect as expected but for sure when you render the scene you get the effect as promised and that is important. Thank you for the Attention Hugs! Cath
face_off posted Fri, 17 June 2005 at 12:46 AM
Cath, at no point does the tutorial mention angular maps! I am totally confused....
Creator
of OctaneRender
for Poser
Blog
Facebook
Mec4D posted Fri, 17 June 2005 at 12:48 AM
ashish_s_india it get not about right it get about the final effect of the work that is done, the visual effect. My Angular map graphic in post # 3 show the view of the poser6 LightProbe with the ZERO Ground on the Z X Y Orbit and the position of the light and it is done right.
MungoPark posted Fri, 17 June 2005 at 12:50 AM
Simple question - where do you position the IBL light and the camera ?
Message edited on: 06/17/2005 00:53
Mec4D posted Fri, 17 June 2005 at 12:55 AM
You don't have to, the IBL light is fixed in Poser6 scene. I used Aux Camera for this scene with ZOrbit :0 XOrbit:0 YOrbit:0
Message edited on: 06/17/2005 00:58
Mec4D posted Fri, 17 June 2005 at 1:06 AM
Paul wrote: at no point does the tutorial mention angular maps! I am totally confused.... then I will tell you go to the doctor and let check out your eyes lol hahahahaha I will not tell you what I think this time... but you get over the limit friend
MachineClaw posted Fri, 17 June 2005 at 1:17 AM
raises hand uh, why if the majority of light from the image (now used as a lightball) is directly behind the statue ...is the statues shadow off at 7 o'clock instead of straight at the viewer at 6 o'clock??? if the 'sun' in the image were shown at the 1 o'clock position I would expect to see the shadow that is shown. I understand the angular map concept but using the flat panoramic gives no "top" or "bottom/ground" Cath - Really trying to understand, honest. English translation sometimes hard. New concept to Poser hard. You rocket scientist, me dumb farmer (not really, but sort of). Please to make easyest. And thank you, you have been trying and doing a lot on the subject, tutorials are wonderful, I just need more understanding.
MungoPark posted Fri, 17 June 2005 at 1:25 AM
MungoPark posted Fri, 17 June 2005 at 1:34 AM
Mec4D posted Fri, 17 June 2005 at 1:35 AM
MachineClaw : the sun shadow changed because the background is just only a background and if I change the focal it change the position you nee really create a sky-dome for things like this, I have a new one in production that works much better and is really fantastic. The flat panoramic graphic it show how the Angular Map looks like on a flat image, it allow you to create own light and light effects just in Photoshop, how to do this I will tell later , it is very cool way and very accurate. And I know sometimes I get to faster and to exciting about the things I do, I understand what I do and I can put it on my scene and renders but my English is not the same so sorry for the trouble.... I will make new tutorials with all information set by step so everyone can get it, I will make also a flash in real time so you don't need to read anything as only follow me on the screen. HDRI and IBL is not simple, I sit in this one year and still learn new things everyday. MungoPark : you got a nice effect, you created the sky light that represent here for real the shadow area, now only the sun light and done!
Message edited on: 06/17/2005 01:36
MachineClaw posted Fri, 17 June 2005 at 1:36 AM
uh so shouldn't the figure be full on spot light'd (sun over cameras sholder) and fading off to darkness if the camera is fliped to 180 degree then ???? I did this once in lightwave with HDRShop and I used a image that was numbered. by rotaing the camera around in the scene the image mapped to the "ball" I could tell where I was in the scene, (also helped to have a photoshop layer I could turn off later for final render when I found the sweet spot lighting effect I was looking for). I see the sample picture of angular map, but I don't see how it applies to the mini tutorial. I think I'm losing braincells more and more with IBL AO HDRI whooit thingy ....
MachineClaw posted Fri, 17 June 2005 at 1:38 AM
Cath - no problem. I understand the translation thing. Keep up the work, slow down, you have my and others attention. I personally think it's a hard subject and can get very confusing. Thanks for trying.
Mec4D posted Fri, 17 June 2005 at 1:45 AM
I think I will use a more simple maps next time. Regarding the figure that MungoPark posted was without the sun light that why it looks like with twinlight so was the map too. If I trun the camera 180degree the venus will be whole in the sun as the rest of the background. For doing things like this you need to make environments so it will be working always no matter what you do with the camera, I made this in the stonehenge so the scene can be used also for animations too.
maxxxmodelz posted Fri, 17 June 2005 at 1:56 AM
I think it's worth a mention, so as not to confuse some people who are new to IBL, that Poser doesn't actually do HDRI lighting. You can adapt a .HDR lightprobe to work with the IBL in P6, but it's still LDR (low dynamic range). Once you save a .hdr to .jpg, .bmp, or .tga, it loses the high dynamic color range, and becomes LDR. Only floating-point .tiff, .hdr, .pic, and a few other formats retain the necessary pixel depth, and Poser doesn't support those AFAIK, and it would require running a process-intensive GI calculation to light the scene. I know you guys in this thread (Cath, Paul, etc.) already know this, but with the term HDRI being thrown around lately, I think it's something that might confuse people, and should be clarified. ;-)
Tools : 3dsmax 2015, Daz Studio 4.6, PoserPro 2012, Blender
v2.74
System: Pentium QuadCore i7, under Win 8, GeForce GTX 780 / 2GB
GPU.
neftis posted Fri, 17 June 2005 at 2:14 AM
Ok I think I am confused..(Neftis takes a big breath) everybody let's calm down;) First Thanks Cath for your tutorials, it requires time to do all those and it's very appreciated from all the comunity I am sure. Now I understand NADA about HDRI IBL LDR AKA LOL RMOF hehe;) So I am trying to understand slowly and thanks maxxxmodelz for the clarification.it's a good start:)
yelocloud posted Fri, 17 June 2005 at 2:14 AM
face_off wrote: " Cath, at no point does the tutorial mention angular maps! I am totally confused...." Angular Map = Lightprobe or Probelight (when it is made correctly, not just a picture of a silver ball, which will get some of desired result, but only to a point, & not as accurate). See Post #15, & then "wrap" that mentally around the diagram in post #3 :-) [sitting back with popcorn now to watch the fireworks smile...& it's not even 4th of July yet, lucky me] Please remember to.... "Love, Peace, & Pose" everyone.
Mec4D posted Fri, 17 June 2005 at 2:22 AM
max you are right and I think it is better if the users know a little bit more about HDRI before they start with LDRI what is a poor child from HDRI. one thing about Poser6 IBL is that you can create the illusion for the eyes and specialist can not recognise it in final render if done good.... a real photo don't include that much information as HDR Image so the process preparing the images is deeper as the user think, it hurt only to see what the user started to do with it and that is my point here to get them off from the totally wrong way of start. It is time to show poser in better light, I self uploaded couple images at CGTalk and with success for the first time people accepted the simple poser scenes with much of nice comments too so I think I am going good way and after so many years I think it is right time for that.... :)
justpatrick posted Fri, 17 June 2005 at 3:10 AM
I have a question that may sound stupid, but here goes... What is the advantage of HDRI over the IBL or low range light that Poser can do? The stuff I've seen so far done in Poser 6 from people like Mec4D, faceoff, maxxx, and others looks just as good as work I have seen done with HDRI in programs like Vue, Maya, 3dsmax, and Lightwave. So what would be the real advantage of having HDRI?
yelocloud posted Fri, 17 June 2005 at 3:13 AM
Mec4D wrote: "It is time to show poser in better light, I self uploaded couple images at CGTalk and with success for the first time people accepted the simple poser scenes with much of nice comments too so I think I am going good way and after so many years I think it is right time for that" Amen to that. A new day is dawning, so isn't it appropriate we "capture" the sun & put in inside P6? :-)
Mec4D posted Fri, 17 June 2005 at 3:18 AM
Attached Link: HDRI
For me for sure it is 10:15 AM and the sun is great!!! I feel good.... justpatrick : see what max wrote in post # 32 please go here and ready about !!!!!! it can be better_________________________________________________________
jrabbit posted Fri, 17 June 2005 at 3:33 AM
jrabbit posted Fri, 17 June 2005 at 3:37 AM
jrabbit posted Fri, 17 June 2005 at 3:39 AM
back
jrabbit posted Fri, 17 June 2005 at 3:40 AM
jrabbit posted Fri, 17 June 2005 at 3:43 AM
Mec4D posted Fri, 17 June 2005 at 3:53 AM
it looks very nice! and that was the intention to show how the light works and where is what. Please see post number: 6 there you can see exact the light setting, the blue areas on the maps that are the light that show up above the ground plane in Poser6, the green area is the light from the floor, if you want get only light from the floor you need to set the blue sky area to black and the green area to the color you wish.. I made a disco ground also it looks like much fun. With the graphics for the Angular Map and the latitude map you can learn to controle better the IBL light in Poser6.
yelocloud posted Fri, 17 June 2005 at 3:55 AM
justpatrick, in a nutshell, HDRI & LDRI are the lighting information, how the environment & everything in it reacts to the light. HDRI records "all" of the available light information, which can then be used to recreate the lighting in a virtual atmosphere, changing brightness etc, accuratly & if the system allows for it, in real time. The IBL /LDRI only records a limited amount of light info, but with additional manipulation, can achieve the "look" of an HDRI scene. The advantage is that with HDRI It's "easier" to accuratly get your scene looking like it does in the "real world", & intergrate virtual & "real" elements together. http://www.debevec.org/ one of the best resources for HDRI & IBL/ Global Illumination work straight from the proverbial horses mouth :-)
jrabbit posted Fri, 17 June 2005 at 3:57 AM
yelocloud posted Fri, 17 June 2005 at 4:01 AM
wow 7 posts between when I responded to your post justpatrick & the post sticking...sigh oh well lol. Who said this thread was dead? The party's just getting started! Thanx jrabbit, just what the doctor ordered, & the "model" will probably help the lesson sink in (at least for the hetrosexual & lesbian population LOL...I joke I kid)
jrabbit posted Fri, 17 June 2005 at 4:10 AM
Mec4D posted Fri, 17 June 2005 at 4:28 AM
Mec4D posted Fri, 17 June 2005 at 4:37 AM
Mec4D posted Fri, 17 June 2005 at 4:38 AM
Mec4D posted Fri, 17 June 2005 at 4:43 AM
neftis posted Fri, 17 June 2005 at 4:50 AM
Cath there is a little white ball in the way, I can't see very well :) LOL
ahaahah
ok I get serious now...and try to read carefully so I can understand correctly everything.This is all very interesting....
Message edited on: 06/17/2005 04:53
Redfern posted Fri, 17 June 2005 at 5:56 AM
The image in post # 50 reminds me of this lil' scene: *** *** *** Doctor: I have good news and bad news. Patient: Yeah? Doctor: the good news is that you have a sperm count of "one". Patient: How's that GOOD news?! Doctor: The bad news is that it's the size of a football and it wants to get out now! *** *** *** Sincerely, Bill
Tempt the Hand of Fate and it'll give you the "finger"!
face_off posted Fri, 17 June 2005 at 6:52 AM
Cath - your image in post 52 demonstrates my point EXACTLY! The sphere is illuminated white from the front, yet is white in the middle of the background. The same thing happened in #51. the whole thing is 180 degrees out.
Creator
of OctaneRender
for Poser
Blog
Facebook
ashish_s_india posted Fri, 17 June 2005 at 8:00 AM
Well, Since all the HDRI Gurus are here, plz help me with a small problem I can't solve. All the light probes I have, don't map around into a perfect sphere. The top and the bottom of the environ don't fit. So, how do I make a perfect spherical environ using my light probes, that ain't blnk at the top and the bottom. (get ref on sphere, see to and bottom of sphere) Help
dagmath posted Fri, 17 June 2005 at 8:09 AM
"Don't do it with an axe, get a chainsaw"
Mec4D posted Fri, 17 June 2005 at 8:16 AM
PAUL and what? the front in in the front where it have to be the right is on the right and left on the left, when you turn it 180 it will dark behind and with red and blue tones the FRONT mean the light is on the front and the rear mean the ight will be on back.... if you create a Light Pobe ANGULAR MAP it is the oposity to the ground, and because I used panoramic image on the first renders the twilight made the wrong illusion for the tutorial. The Angular Map is nothing else as 360 degree Light Projector and nothing more ... AMEN ashish_s_india I am working on a freebie, excellent one with so funny mapping that it will take you 2 min to map it with your own sky maps.. need some days to finish everything before my b-day including also texture freebie for ! A.Maximus with some nice skin shaders... yea I am working on too... we go to make a HUGE 3D party next weekend !!!! lol I am not kidding
Mec4D posted Fri, 17 June 2005 at 8:22 AM
dagmath the one mistake I did was to cut the image for the background from the middle, other as this was everything perfect..... now I see the rest is perfect, that why I hate bakgrounds. Better to use the panoramic image direct on the hemisphere sky-dome and no problems.
maxxxmodelz posted Fri, 17 June 2005 at 8:24 AM
"All the light probes I have, don't map around into a perfect sphere. The top and the bottom of the environ don't fit. So, how do I make a perfect spherical environ using my light probes, that ain't blnk at the top and the bottom." That's because you're probably using a lightprobe that was created with a mirrored ball. These won't contain all the environment in them when unwrapped... there's going to be a certain percentage that's left out. You need to get good HDR images that were created using a highend 360 degree camera, preferrably in longitude/latitude (environment mapped) format. Either that, or unwrap the probe to longitude/latitude in HDRshop, and then save it as a bmp or tiff, and edit it in an image editor (fill in the empty areas with the clone brush) to use as your spherical environment.
v2.74
GPU.
Mec4D posted Fri, 17 June 2005 at 8:28 AM
Coveryjoo posted Fri, 17 June 2005 at 8:30 AM
Thank you so much Cath for this tut ! Cant wait to try it out ;)
Mec4D posted Fri, 17 June 2005 at 8:32 AM
Please use the first Angular Map I made for the sky is important other it will not working again....
Mec4D posted Fri, 17 June 2005 at 8:48 AM
face_off posted Fri, 17 June 2005 at 8:53 AM
Cath, that map look suspiciously like it's been rotated 180 degrees! OK, that's half the problem solved. Now you just need to mirror it and we are there.
Creator
of OctaneRender
for Poser
Blog
Facebook
Mec4D posted Fri, 17 June 2005 at 9:20 AM
yes mirror the panoramic background and it perfect100% I saw this just before your post, I am just to tired have to break out for a moment. The problem I show was on the background... I did this at home good , that why I had not problems at all, my scene was rotated 180 degree I just save I go next week to make new Angular maps with a Real Light Probe for sky sun and diffuse, I just ordered system to doing it... it will be much fun to create new REAL scenes for poser6 users!!!!
ju8nkm9l posted Fri, 17 June 2005 at 9:29 AM
I'm bookmarking this thread.
stallion posted Fri, 17 June 2005 at 9:38 AM
ditto..
You might as well PAY attention, because you can't afford FREE speech
MachineClaw posted Fri, 17 June 2005 at 9:52 AM
so the background is flipped 180? I thought it was stationary. okay I'm turned around again...is that 720? Have we come full circle yet? (some days I do believe that I have become the dumbest man on the planet)
Mec4D posted Fri, 17 June 2005 at 10:07 AM
MC flip the image from the post # 61 horizontally to your left and everything is solved the rest as from post # 64
ChuckEvans posted Fri, 17 June 2005 at 10:12 AM
Interesting.
Mazak posted Fri, 17 June 2005 at 10:13 AM
Thank you Cath, every day we learn something new... Learning by doing :D Cath you definitely need reopen your own forum, we speak already about it; to have the full control ;) Mazak
dagmath posted Fri, 17 June 2005 at 10:52 AM
Robo2010 posted Fri, 17 June 2005 at 11:12 AM
Mec4D posted Fri, 17 June 2005 at 11:41 AM
Attached Link: The Day of The Dragon
:) click the link above_________________________________________________________
jrabbit posted Fri, 17 June 2005 at 1:06 PM
jrabbit posted Fri, 17 June 2005 at 1:10 PM
Singular3D posted Fri, 17 June 2005 at 3:52 PM
Wow. Bookmark!
Tiny posted Fri, 17 June 2005 at 3:58 PM
Thank you Mec4D for showing this. :o)
face_off posted Fri, 17 June 2005 at 4:15 PM
jrabbit, doesn't look like anything was flipped there. Cath, it's a bit hard to tell, but the mini-tutorial still doesn't look right. The reference image needs to be flipped. I think it would also be good to explain that this needs to be done (and the image needs rotating 180degree) in the tutorial instructions, since although I can see you've rotated the background 180 degrees, there are no instructions to do it, and it would be easy for people to miss. I guess a reminder too....I posted a tutorial along similar lines 2 days ago, and it's includes a free python script to do most of this for you! If you are going to the trouble of running HDRShop for image manipulation anyway, it's quicker, easier and more accurate to let the python script do all the work for you in Poser than to do it all by hand (as you've described here).
Creator
of OctaneRender
for Poser
Blog
Facebook
kobaltkween posted Fri, 17 June 2005 at 6:21 PM
ok, i want to try to verify my understanding of this and blend this tutorial with pauls (face_offs). why blend? because i really like terragen (there's a tutorial for making full 360 cubes and panos with it) and it's easier for me to fake a quick panorama than it is for me to make a mirror ball set up. so, basically, paul was right, which makes sense from the above renders - especially the one using infinity cove. objects look lit from the front, but have a background showing back lighting. so here's what i'm thinking in terms of basic steps. 1. Make panorama with environment renderer, camera or even image editor. 2. Use HDRShop to make the panorama into an Angular map/Lightprobe. 3. Use face_off's script to set up scene. Use notes from both tutorials for tweaking. (by the way, i can't get to face_off's tutorial right now - it's timing out trying to get to the server. someone let me know if they do or don't have problems. 4. Make a background using the ends of the pano (grey in dagmath's image). Combine them such that the rightmost piece is on the left and the leftmost piece is on the right and the join (their ends) are in the middle. This requires horizontally flipping the leftmost piece. That's just my present understanding. Let me know how accurate that is. And I just want to say kudos and thanks to both of you for taking time and effort to help the rest of us Poser peasants advance ourselves. Your works (and notably maxxxmodelz's) show that Poser can be more than a toy or a plastic/airbrush pinup factory.
Tashar59 posted Fri, 17 June 2005 at 6:21 PM
BM
Mec4D posted Fri, 17 June 2005 at 6:55 PM
Will be anybody understand anything from this mess? it is hard to follow I think, I am going set my tutorial on separate paper, it was not finished here because I don't say anything about the SUN light... I am going to do this as I do for my last 2 months with my own idea, my images in my gallery speak for that self ... I don't want to see this as an competition with face_off tut what is fine too.... and as always the final image say more that 1000 words...
jrabbit posted Fri, 17 June 2005 at 8:27 PM
LOL Paul are you serious ? you cant see the difference of highlights on the sphere ? The fliped envirionment map causes the highlights to blend LOL just look both edges are now purple !!! The render above it all the colors are where they should be. If you dont think I actually fliped the light map ? maybe I'm faking it? LOL why bother? TRY IT. Try loading the test rigs exactly as they present. You will see. By the way caths map of the light probe , because it uses red yellow and blue seems brighter on the yellow and red directions. blue is colder red hotter. making an illusion the light is stonger in the red and yellow directions. as seen in #40. And further the yellow Front section is a warm color so the center in all directions is bright ! :)) You know dosch sells a hdri cd , with matching back grounds . I've been using them in lightwave for ten years , you dont flip the maps you rotate the model HDRI light never moves , but as you rotate the model it appears the light has changed. Some one said it above and they where right .... find the matching spot using numbered grids. Basically we have to accept that this is FAKE light made by software , histograms generated by light maps , and programming code. And live with how it actually applies and how to make the best illusion from it. I am certain flipping the map is wrong but if you cant see it kill the specular , reflect , radiosity ect so be it. look what flipping the map did to the real skin shader on the girl between post 76 correct and 77 fliped incorrect. Cath your original idea works better than flipping because as my very last picture shows the light hitting the ball mixes with the reflection on the background and makes mud of the highlights (PURPLE EDGES). thats all wrong. look the orange on your lattitude chart is yellow now , the skin has lost it reds ect. Paul you of any one should see that clearly. By the way dont see a mention for the fact that flipping the map still doesnt stop the light from comming from the front. only shifts it from left to right. To actually make the light come from behind we need a black centered light map , with bright edges. But now it wont match the environment. so easy to prove. we are leaning so much. Thanks. The Rabbit
kobaltkween posted Fri, 17 June 2005 at 9:35 PM
"To actually make the light come from behind we need a black centered light map , with bright edges." That's the point. The background image shows the sun behind the object, or in some cases, people. What we see is an object lit from the front. That's why you can't just take the middle of your pano and put it in back of your scene - it's actually lighting the front of your scene. That's why you need to put what goes in the back behind the main object. This is the sides of the pano and the edges of the problight. Think of the pano as actually being in a ring around the object, casting light. The middle is directly in front of the object, and the edges meet behind it. So it's a 180 degree shift along the pano. But you're turning. So it's a mirror image - the right is now on the left and the left is on the right. At least, that's my understanding.
kobaltkween posted Fri, 17 June 2005 at 9:43 PM
and i'm not thinking of these tutorials as competing, but completely complementary. your images are beautiful and incredibly realistic. i think i get this tutorial (though i'm not sure), and i'm truly appreciative of all the work you put in to actually share what you learned, which is quite selfless. i think everyone here appreciates what you and face_off do, and benefit a good deal from your conversations.
kobaltkween posted Fri, 17 June 2005 at 10:12 PM
oh, and i can get to face_off's tutorial now. i hadn't been able to look at it as closely before - so i can see how different the approaches are now. both seem excellent. i'm saving both to my hard drive.
face_off posted Fri, 17 June 2005 at 10:59 PM
jrabbit - I'm looking at your posts 76 and 77.
The theory is....to get the background to match your ibl lighting, you need to a) rotate your Poser sene lighting 180 degrees around the y axis AND b) flip the background image in the x axis (ie. mirror it). There are a number of ways to do this.
One way is to use my python script.
The other way is to do this manually in HDRShop: Load the mirrorball image. Take the middle as the background image and flip it in the X-Axis (ie. mirror). Take the original mirrorball, Convert to lat/long, pan 180 degrees (as Cath did in 64), convert back to mirrorball and save for use as the IBL image.
An even easier way it to setup IBL in Poser 6, rotate your whole scene 180 degrees in the Y Axis (so the camera is looking from behind), then use a flipped version of the middle of the IBL as your Poser background.
Any of these methods should work!
This was covered in my tutorial from a couple of days ago, but as I use a python script to do it (method 1), I clearly didn't explain it in enough detail, and should have provided much more detail - which I apoligise for.
Now, back to your images....the background is the same in both post 76 and 77. Thus my comment "jrabbit, doesn't look like anything was flipped there". But you are right - the highlights HAVE been flipped, which escaped my notice (since I was looked for a background flip) - my mistake. But looking again - both renders are incorrect. You've got WHITE as the FRONT color showing in the ball, but white is also at the centre of your background. The centre of your background should be grey. I think that having reflections on that sphere is confusing you. Turn them off and just have diffuse (which is what I did in post 14 to highlight the problem).
This is incredibly simple once the penny drops, you just need the think outside the square (sphere???) in order to get the concept.
Message edited on: 06/17/2005 23:03
Creator
of OctaneRender
for Poser
Blog
Facebook
PabloS posted Sat, 18 June 2005 at 12:14 AM
~bookmark~
jrabbit posted Sat, 18 June 2005 at 2:15 AM
face_off posted Sat, 18 June 2005 at 2:59 AM
Creator
of OctaneRender
for Poser
Blog
Facebook
jrabbit posted Sat, 18 June 2005 at 4:03 AM
LOL LOL yeh well I fliped both to exparement each seperately of course to test render. They come out the same either way... try it dont just scold me because I dare to see the effect. Who cares what wasnt said where testing all ideas , dont we all wanna know whats bull and what works ? :) And its obvious after testing flipping either does not change several issues but creates new ones. all it does is reposition light from left to right or right to left NOT front to back. post 48 I clearly showed what IBL map I used. jimmny crickits. Humm somethings amiss Paul. My test rig is very basic No tricks or secret , just infinity cove with caths lattitude map diagram on it and on IBL light with her IBL light diagram pluged in as the light map. My results are not yours as we can see. posts 40, 42 ,43 ,76 , and 77 are just the angular map in post 49 for the IBL, and caths lattitude map on the back drop. Very simple test rig. If the light matches the backdrop colors will not conflict but be correct and sphere will behave as light map dictates. if I flip the back ground or the IBL (doesnt matter same result)you get the effect that seperates 76 from 77 ... Try it dont just say sure.. LOL than you'll see the whole scoop. My point is for me that caths Idea works fine for her ...she built around how poser behaves. but you find flaw and seek to push your script. But I test your idea against hers and find a new flaw thats worse in color effect. That you dont seem to see or address. If you flip back ground light is out of phase. LOL "At what point did reflections come into this? Bring reflections into the equation is just giong to confuse you even more. Get the basics right first, then take it from there." At the title realizm . If I stand against a brick wall and have a white shirt on with my hand out. A ping pong ball in it and you face me and the wall the ball is white still LOL the edges are colored by my hand both by reflection and radiosity. If on the left is blue light the right red bottom green top yellow the edges of the ball pick up the colors. just as post 76 I got what your saying Paul thanks. Maybe slightly smarter and experianced than you think. Maybe Hummm your not seeing the problem because your focus is on your idea and not what my rig shows. I honestly would Love for Cath to finish her tut ... Reminds me of eki's days and lightwave. He and Cath seem on the same flow ... know how the software behaves and trick the camera for top realizm.Poser 6 does rock ! Sorry Cath to disrupt. Night all. Jrabbit
face_off posted Sat, 18 June 2005 at 5:52 PM
"But I test your idea against hers and find a new flaw thats worse in color effect. That you dont seem to see or address." jrabbit, in which msg did you try out the instructions from post 88?
Creator
of OctaneRender
for Poser
Blog
Facebook
jrabbit posted Sat, 18 June 2005 at 8:46 PM
face_off posted Thu, 23 June 2005 at 5:20 PM
Jrabbit, the lighting on the girl matches the background correctly....so you are almost there. I'm currious as to why the ball is white at the front, and why the light on the ball doesn't match the girl. I can only assume that it's a ray-traced reflection????? Maybe it would be easier if you emailed the scene to me - at XXXXXX and I can find out why. [edit: email removed for spam reasons. jrabbit - still waiting on that scene]
Creator
of OctaneRender
for Poser
Blog
Facebook
yelocloud posted Tue, 28 June 2005 at 3:01 AM
Message edited on: 06/28/2005 03:12
yelocloud posted Tue, 28 June 2005 at 3:03 AM
yelocloud posted Tue, 28 June 2005 at 3:06 AM
yelocloud posted Tue, 28 June 2005 at 3:07 AM
yelocloud posted Tue, 28 June 2005 at 3:11 AM
