designerin opened this issue on Jun 17, 2005 ยท 5 posts
designerin posted Fri, 17 June 2005 at 2:52 PM
So, i reinstall Poser 6, cause it crashes after start up, when i click with my mouse somewhere in the Window. Poser 6 was running good for maybe 4 weeks. Suddently these crashes. After reinstalling and install SR1 it crashes again, no error messages before. Can someone help? Doesn't matter with or without SR1.
Message edited on: 06/17/2005 14:53
DCArt posted Fri, 17 June 2005 at 3:07 PM
Did you change anything else in your configuration between the time it was working and when it started crashing?
gmadone posted Fri, 17 June 2005 at 4:20 PM
The latest video drivers? What OS
designerin posted Fri, 17 June 2005 at 10:28 PM
No, nothing changed, the newest drivers are on it, OS is Prof. XP with SP1, Graphiccard is an Asus V9570, CPU AMD Sempron 2400, Memory 1 GB of DDR Ram.
gmadone posted Sat, 18 June 2005 at 8:50 AM
I would update the video drivers anyway. (fixes 90% of crashes) If that is not it then a reinstall might be in order, be sure to back up your files and empty the P6 folder (it may be a bad file, most likely in the prefs folder), be sure nothing is running in the background when you reinstall (virus, firewall, spyware or detectors) Contact EF give them all the info you gave us plus details about the crash (does it take the OS down too, do you have to use task manager to end poser, any error messages, crash is a very general term and could mean a lot of things) Good luck.
