Kanda opened this issue on Jun 18, 2005 ยท 14 posts
Kanda posted Sat, 18 June 2005 at 6:10 PM
I want to make a clothe in Lightwave 7 for to use in Poser 5 library as Clothe Conform. The only problem is: The Lightwave dont export the .obj file with group data. So, is useless make the .cr2 file. Somebody know this problem? Exists a plug in for solve this? The alternative is select parts of clothe in Group Editor of Poser 5 and transform it, but is a imprecise and tedious work!
DominiqueB posted Sat, 18 June 2005 at 6:38 PM
As of version 7.5 Lightwave exports the body groups just fine. Select the vertices and go to View< create part. There is no need to split the vertices for your body parts, I never do in my clothing. If you go heavily into clothing I would recommend Greenbriar's cr2 loader plug-ins for LW I couldn't live without them.
Dominique Digital Cats Media
DCArt posted Sat, 18 June 2005 at 6:53 PM
Kanda posted Sat, 18 June 2005 at 11:47 PM
Thanks, brothers!!! DominiqueB, I use the version 7 and dont found the path "View > Create Part". Maybe, just from version 7.5 can be possible the process. Your recommedation about the plug in is registered for my researches. Deecey, the Auto Group Editor seems dont play in Windows 98 - my old system...hahaha. I feel myself obliged to change. I go search about UV Mapper Pro.
nruddock posted Sun, 19 June 2005 at 4:50 AM
Have you tried saving as a Lightwave5 file and importing that into Poser ?
Kanda posted Sun, 19 June 2005 at 8:35 AM
Yes, nruddock. No success too!
DominiqueB posted Sun, 19 June 2005 at 9:23 AM
The 7.5 update is free at Newtek, you should install it will solve all your problems.
Geodesic250 posted Sun, 19 June 2005 at 1:05 PM
DominiqueB, I also have Lightwave 7.5 and I can't find View > Create Part. I know about Display > Grouping > Change part name but my 7.5 doesn't have a View let alone a View > Create Part. Please, tell me where it's hidden as I'm still learning :)
Kanda posted Sun, 19 June 2005 at 2:25 PM
Yes, Geodesic. This menu also exists in version 7. Dominique, the version 7 also have Display > Grouping > Change Part Name, Point Selection Sets and Surfaces to Parts. But, what the procedure?! To select a group (Point Mode) and...what the next step?
DominiqueB posted Mon, 20 June 2005 at 8:50 AM
Sorry if I confused you guys, I was going from memory. The correct path for 7.5 is Display Change Part Name ( I have been working with 8.0 for a while so I forgot where stuff was in 7.5).Change Part name is what you want. Simply select the polygon of the body part you want and hit Change Part name give it the EXACT same internal name as the Poser part (i.e. Left Shoulder is in reality lShldr for Poser) Do that for all body parts. Do not use Point selection sets, if you have any for any reason, you must get rid of them Poser does not like them. Once you have all your body groups and surfaces declared, and the uv mapping is done do not forget to assign the uv map to every surface in the surface editor. If you do not do that once loaded in Poser you will not able to assign any texture maps. Once all that is done export the obj. Import it into Poser it will be there with all it's body parts, then you can start conforming.
Kanda posted Mon, 20 June 2005 at 10:03 PM
Nice explanation!! although I not to be able to test now due to problems in my operational system (I installed Win 2000 today), the communication have nexus. I believe that this process also functions in LW 7. Thanks very much, Dominique!!
nio103 posted Tue, 21 June 2005 at 10:13 AM
DominiqueB where can i get Greenbriar's cr2 loader plug, Auto Group Editor, or can you send them to me to nio102@yahoo.com ill be waiting for them :)
DCArt posted Tue, 21 June 2005 at 10:28 AM
You have to purchase both of them. We don't trade or give away warez here. You can purchase Greenbriar's CR2 Loader from http://www.greenbriarstudio.com/3D/ And you can get the Auto Group Editor from the marketplace here. http://market.renderosity.com/softgood.ez?ViewSoftgood=21081
nio103 posted Tue, 21 June 2005 at 7:16 PM
I thought they where free plug-ins lol Thanks Deecey for the links i'll check them out. Sincerely, Manuel
