Subject: Poser 6 Save Problem
DrowVampyre opened this issue on Jun 20, 2005 ยท 6 posts
DrowVampyre posted Mon, 20 June 2005 at 3:01 AM
Hi. Within the past few days, a rather strange (and frustrating) problem has begun to happen when I save my scenes. The save seems to work fine, and the file isn't 0kb (as is sometimes the case when a save error occurs). However, when I reload them, the scenes are gone. Everything is in wireframe mode, the poses are totally gone, the lighting is gone: everything. This has only happened in the past few days, and I can't figure out why. Has this happened to anyone else, and if so, how did you fix it? (By the way, this is Poser 6, running on Windows XP.)
Dizzi posted Mon, 20 June 2005 at 7:30 AM
Do you have file compression enabled? I had that problem in P5 and P6 when it was enabled... Didn't occure since it's off ;-)
DrowVampyre posted Mon, 20 June 2005 at 7:42 AM
Hmm...nope, compression's off, but external morph targets is on. Could that be it?
Dizzi posted Mon, 20 June 2005 at 12:14 PM
I'd try that at least...
paper-tiger posted Mon, 20 June 2005 at 1:27 PM
I have the same problem, but the files only get corrupted when I get an Out of Memory error. I've just learned to save two different copies of everything, and switch between them - then when one corrupts, I open the other and save-as. :/ It's a pain, but less of a pain than starting over completely.
evilded777 posted Tue, 21 June 2005 at 7:55 PM
Same odd issue for me, only occaisionaly. Have yet to pinpoint any specifics. Has only started happening since SR1. Other things since SR1: The return of crosstalk? Full body morphs cease to function when similar figures are loaded in a scene (ie 2 m3, 2 m3 1 d3, etc) Sometimes can not import PZ3 files; the only way around the above issue is to create seperate pz23 files and merge them. Today I find that I sometimes can not properly import a saved pz3. Seriously thinking about going back to pre-SR1.
