Subject: Rendering Questions
ethan opened this issue on Jun 20, 2005 ยท 6 posts
ethan posted Mon, 20 June 2005 at 3:24 AM
Hi, i just got my Poser 6 and its blowing me away :) (Compared to Poser 5). I have a question. HOW can i render a animation with a alphachannel (transparent Background) ? And Where can I find good BVH motion capture files for Poser 6? Thank you very much and have a nice day ;-)
Little_Dragon posted Mon, 20 June 2005 at 4:30 AM
  1. Render to image sequence, using an image format that supports Poser's alpha channel (PNG, TIFF, PSD).
  2. Render to AVI, using a video codec that supports Poser's alpha channel (Huffyuv, Lagarith). You'll need to configure both codecs to "Always suggest RGB for output", and with Huffy, at least, you'll need to enable the RGBA option.
You'll find a wide variety for sale here in the Marketplace, at DAZ 3D, and at Credo Interactive.
As far as free mo-cap is concerned, your mileage may vary. Most of these weren't designed specifically for Poser figures, and will usually require some tweaking after import:
http://acabar.cafwap.net/~zier/anim/
http://www.e-motek.com/entertainment/index.htm
http://www.mastudios.com/motion.html
http://www.help3d.com/
http://www.cs.wisc.edu/~pingelm/ComputerAnimation/bvh.html
http://www.ict.usc.edu/graphics/animWeb/humanoid/sampleData.html
http://www.bvhfiles.com/
http://www.hypervision.co.uk/
And the free 30MB archive from Santa Monica Studios, containing over 200 .bvh files:
http://movement.stanford.edu/santa.zip
almostfm posted Mon, 20 June 2005 at 4:31 AM
Ethan, If you render out the animation as individual images, you can save them as tiff files, which I believe has an alpha channel. Unfortunately, you'd then have to do whatever postwork you're going to do on every frame... Can't help you with the BVH motion--I'm looking for some of those myself.
ethan posted Mon, 20 June 2005 at 4:50 AM
Thanks! I think i will render single frames and combine them in aftereffects. How do I render the char in poser without background?
TrekkieGrrrl posted Mon, 20 June 2005 at 4:56 AM
Poser's usual grey "background" is an alphachannel. So.. just render and the alphachannel is there all by itself (if you, as L_D said, save the pics in a format that supports an alpha channel, of course)
ethan posted Mon, 20 June 2005 at 5:06 AM
ahhhh great! Thank you. I was confused as I rendered it and there was this grey bg. thanks mate
