speedgoat opened this issue on Jun 22, 2005 ยท 6 posts
speedgoat posted Wed, 22 June 2005 at 3:38 AM
Hi Is there a possibility to copy objects in Poser 6? For example for building a fence? Or do I have to import and scale every pole again and again? thanks for your answers
JohnRickardJR posted Wed, 22 June 2005 at 3:56 AM
The easiest thing to do is add the first post back to the prop library, then add that modified post back to your scene. If you don't need the post again, delete it from the library
nukem posted Wed, 22 June 2005 at 4:46 AM
Cast Iron Flamingo has a freeware Python scripts bundle called the GPA Script Pak 1 that include two scripts that allow you to clone figures and props.
geep posted Wed, 22 June 2005 at 11:02 AM
... Or you could just use the Grouping Tool ...
... like this ...
The "NewProp x" is already selected after it is created and can now be moved to a new location and then duplicated again to produce the next prop.
You do not need to exit the Grouping Tool until you are finished duplicating the objects.
If you are interested ... This is the process that could have been used in the Picket Fence Tutorial.
cheers,
dr geep
;=] Edited to remove all Nudity, Violence, dirty language, TOS violations, and TOP SECRET information ... as usual. ;=]
Message edited on: 06/22/2005 11:11
cheers,
dr geep ... :o]
edited 10/5/2019
geep posted Wed, 22 June 2005 at 11:09 AM
cheers,
dr geep ... :o]
edited 10/5/2019
JohnRickardJR posted Wed, 22 June 2005 at 12:28 PM
Ok, that would do it as well..
