polartech opened this issue on Feb 13, 2001 ยท 3 posts
polartech posted Tue, 13 February 2001 at 3:43 AM
. . . multi-select a range of keyframes (like when you sweep the mouse over a range and the area is highlited), but then drag that RANGE up or down, as a whole set of value changes. The reason is that I have Mimiced a head speaking some dialogue, but want to twist the head so that it is at a three quarter angle to the camera. Mimic has already applied subtle changes to the twist parameter, which I would prefer to keep, just change the whole range of points. I know you could do this with a change to the cameras position, but it has other uses this way, if it
s at all possible. Thanks !
JeffH posted Tue, 13 February 2001 at 6:53 AM
Yes, just use the SHIFT key when you select the keyframes with the cursor.
polartech posted Tue, 13 February 2001 at 9:53 AM
Aha... yet another gem ;-) Many thanks Jeff, once again.
