Subject: Help!!! Problem importing Poser 6 files into Vue 4.2
ericwestray opened this issue on Jun 24, 2005 ยท 9 posts
ericwestray posted Fri, 24 June 2005 at 9:36 AM
Hi Everyone,
I had no problem importing my Poser5 into Vue4.2, but
since I upgraded to Poser6, my files will not import. I keep getting error messages. Please advise. Thanks,
Eric
randym77 posted Fri, 24 June 2005 at 9:38 AM
I suspect Vue can't read P6's external morphs. Try turning off the external morph thing in P6.
dlk30341 posted Fri, 24 June 2005 at 9:45 AM
Hve you pointed Vue to your Poser6 exe??? Maybe someone with some more knowledge can chime in here, but I'm not sure if Vue 4 has been updated to use P6. Just a couple more possibilities.
Fazzel posted Fri, 24 June 2005 at 10:05 AM
I take it you don't read the forums at E-on's website. Anyway they are waiting to get the SDK (?) from E-Frontier for Poser 6 SR1 so they can modify Vue to work with it.
dlk30341 posted Fri, 24 June 2005 at 10:24 AM
As stated above.
Djeser posted Fri, 24 June 2005 at 10:55 AM
I doubt whether Vue 4 will be updated to take Poser 6 files; Vue 5 and Vue 5 Infinite are the most recent products, and Vue 4 is about 3 years old. If Poser 6 has an option to save as a Poser 4 or 5 file, that might do the trick.
Sgiathalaich
Puntomaus posted Fri, 24 June 2005 at 2:06 PM
Vue 4 will not be updated anymore to work with P6. I've asked about that a few weeks ago in their forum and got this answer from a E-on tech support. Vue 5, Vue5 Pro and Vue 5i supports P6 but not Vue4. That's why I finally decided to upgrade to Vue5.
Every organisation rests upon a mountain of secrets ~ Julian Assange
wrpspeed posted Fri, 24 June 2005 at 9:25 PM
i still use poser 5 for vue 4 imports.
artistheat posted Sun, 26 June 2005 at 9:15 AM
If you want to import Poser into Vue you will have to use Poser 5.I also tried importing from p6 to V4 and it didn't work:(
