Colm_Jackson opened this issue on Feb 14, 2001 ยท 11 posts
Colm_Jackson posted Wed, 14 February 2001 at 6:02 PM
Attached Link: 3D Vision
I used the 'Add Muscle Mags' Pyhon script ulility on a new figure. It works really well. Except I can't permanently delete the magnets. I delete them. Load the file in again and they are still there. Anyone know how to remove this from a Pz3??? Thanks, Colm...shadowcat posted Wed, 14 February 2001 at 6:14 PM
Did you resave after you deleted?
Colm_Jackson posted Wed, 14 February 2001 at 6:39 PM
Yes...
PhilC posted Wed, 14 February 2001 at 8:38 PM
Colm_Jackson posted Wed, 14 February 2001 at 10:52 PM
No Phil, That doesn't work. They are still there. The Python Script text box comes up too when the file is loaded... Colm...
Colm_Jackson posted Wed, 14 February 2001 at 11:01 PM
Actually, I have just realised that this happens only with Pz3's and not cr2's. So a quick work around would be to save as a cr2 first and if you need a pz3 then reload the cr2 and save as pz3. ACK... Hold on, that doesn't work... The bloody things are back!!!!
milamber42 posted Wed, 14 February 2001 at 11:11 PM
Is the Add Muscle Mags a packaged script that comes with the pro pack?? Even though I do not have Lightwave or MAX, the scripting makes the upgrade worth it for me.
Colm_Jackson posted Wed, 14 February 2001 at 11:24 PM
Yes it comes packaged with PPP but it only adds one magnet to each arm. I just decided to try it on a figure I am working on as an experiment to see how well they worked. I deleted them (as I thought) and then re-saved the pz3. It seems like I am now stuck with them... The script has the potential to be very powerfull. You only have to use 'Bushi's' face randomizer to see what the future could hold...
milamber42 posted Thu, 15 February 2001 at 12:21 AM
I'm a programmer, so I already have some things planned. I want to see what I can do with python and animations.
milamber42 posted Thu, 22 February 2001 at 5:22 PM
Colm, I've got the pro pack now, but I still can not find the 'Add Muscle Mags' script. Is it part of the sample script and buttons? If not, then do you know the .py filename?
milamber42 posted Thu, 22 February 2001 at 7:52 PM
Colm, Never mind! I found it under CallBacks.
