Forum: Community Center
Subject: "mark-all-read" & lost messages... hmm... rcook?
MartinC opened this issue on Feb 16, 2001 ยท 10 posts
MartinC posted Fri, 16 February 2001 at 2:58 AM
I've always been a bit suspicious, but if I remember it correctly then I've been told that the "mark all read" will never hide messages which you haven't seen. I got a little chat with rcook on a thread some time ago, when I asked exactly this question: What happens if I start to read multiple pages and then hit "mark all read" on (let's say) page 5 - I think rcook told me that it will not hide new massages/replies that were posted after I started reading page 1. This sounded reasonable, because often after hitting "mark all read" the "message counter" immediately showed non-zero. But... yesterday I started reading 26 messages (page one said 1-25 of 26), then I went to page two - and it suddenly showed two remaining posts (labelled 26-27 of 27). I hit "mark all read"... and the message counter showed zero! I moved in, and there was nothing indeed, but when I went to "archive", a new topic was on front. Is this a change in the way how "mark all read" works, or just an unlucky glitch?
MartinC posted Fri, 16 February 2001 at 2:59 AM
Oh dear... messages, although a button hiding massages could be handy as well... :-) :-) :-)
rcook posted Fri, 16 February 2001 at 7:52 AM
The "Mark All Read" feature will mark all messages as being read that are older than the current date/time. It does NOT track the actual messages you have read.
RimRunner posted Fri, 16 February 2001 at 9:21 AM
In this case (I've seen it before), when you went to page 2, you refreshed your pointer (date/time as RCook says), thus, the "27th" message was visable to you. I have also had this happen in C&D where there are some very long threads. I go in to read one and by time I come back to the new messages, more have shown up. Since they do not track the actual messages (would be a huge burden on the server side to fag each message), you have to kind of watch out that you don't miss something. Takes a little getting used to, but it's better then some other systems I've seen out there :)
The doctor says I have way too much blood in my caffeine system.
MartinC posted Fri, 16 February 2001 at 10:13 AM
I'm perfectly aware that the server doesn't track the actual messages, but earlier discussions about this topic somehow implied that it track the time when I start reading (eg when I click into the Poser board) and then marks that - this is a big difference. Let's say I enter the board at 10am and read slowly to the final page until 11am. If I hit mark-all-read, will it hide everything older than 10am, or everything older than 11am? Earlier answers implied 10am, but now I'm afraid it is rather 11am.
MartinC posted Fri, 16 February 2001 at 10:19 AM
Suggestion: If I'm right now (that you can't track the enter time to the individual board), I think you should use the log-in time - showing some few threads a second time is better than loosing some completely.
rcook posted Fri, 16 February 2001 at 10:20 AM
The time is set when you enter the thread listing page. If you view a thead and hit back, the Mark All Read time will remain the same. But, if you go to a second page of thread listings by hitting Next, the time will be updated.
MartinC posted Fri, 16 February 2001 at 10:24 AM
Is there a chance to keep the time from the first page (another cookie?) - if it updates like you say now, it is very bad - if you spend 1 hour reading a whole lot, you will probably miss everything that got added/updated in between.
RimRunner posted Fri, 16 February 2001 at 10:30 AM
I've also noticed if you hit the "read new messages" at the bottom of a thread, again, it updates your time, so new messages could be there. In some active threads, this means going back into them to get the newest comments. :)
rcook posted Fri, 16 February 2001 at 10:48 AM
Yeah, could be Martin. I'll look into trying to keep the time you first entered the forum.
