CemAygun opened this issue on Jul 06, 2005 ยท 3 posts
CemAygun posted Wed, 06 July 2005 at 3:17 AM
Well, I have a problem with animation in poser. All I need is to ease-in and ease-out off some poses, so that the animation slows down as it reaches the pose, and speeds up slowly as moving out of it. This was quite easy with ligtwave as you can specify a spline tension for each keyframe in the animation palette. With poser, you have the graph editor, I know...But making the adjustment for each and every parameter of the pose does not seem logical...Is there a way to edit the spline behaviour for all the figure at once? Any help would be greately appriciated, as I am desperate...
Rance01 posted Wed, 06 July 2005 at 8:14 AM
CemAygun, You might try the re-time animation. That will change animation speeds through a selected number of frames. Also use plenty of keyframes between changes of motion direction. I do feel your pain, Rance
CemAygun posted Thu, 07 July 2005 at 2:43 AM
Well that's what I do (adding a lot of keyframes) at the moment...But it hurts a lot when you want to make some major changes in the animation as you have to edit all the keyframes back and forth. I was hoping that there was some sort of python script for that... Thanks for the support though...
