Subject: What key commands do you use most often?
onimusha opened this issue on Jul 09, 2005 · 14 posts
onimusha posted Sat, 09 July 2005 at 9:56 PM
Someone's post made me realize how many key commands that I don't use in P6. I've been using Poser for a year now, and find myself not really using it as efficiently as I can. So I'd love it if people shared the shortcuts they most often use...
SamTherapy posted Sat, 09 July 2005 at 10:15 PM
I tend to avoid using the keyboard shortcuts since Poser's key commands are laid out so badly. I do, however, use the numeric keypad for typing values into the dials.
Nance posted Sat, 09 July 2005 at 10:34 PM
In the "Most Often - in a Row category, for me it would be: CTL+DOT DOT DOT DOT DOT DOT DOT DOT DOT !!!! ...when trying to abort a render upon realizing that I still haven't fixed the original problem that caused me to stop the previous render.
destro75 posted Sat, 09 July 2005 at 10:52 PM
Ctrl+C to copy the dial parameter value I am about to FUBAR...Then the keypad to do the FUBARing...Then Ctrl+V to fix. I don't trust Undo ;-) I never use the keyboard for anything else though. With my hand already on the mouse, it's easier to just click around to what I need to do.
wheatpenny posted Sat, 09 July 2005 at 11:02 PM Site Admin
I regularly use ctrl+M (switch to Main camera), shift+ctrl+H (restore camera), ctrl+Y (render settings) and ctrl+R (render).
Jeff
Renderosity Senior Moderator
Hablo español
Ich spreche Deutsch
Je parle français
Mi parolas Esperanton. Ĉu vi?
GabrielK posted Sun, 10 July 2005 at 12:07 AM
CTRL M,Y,U, and R most often, along with whatever blasted key on the keypad splits your camera view into multiple ports. That last one isn't intentional but I end up doing it a lot after trying to input values into the various dials. Other than that, I almost never use keyboard shortcuts in Poser. Kind of odd considering how often I use em in other programs.
mathman posted Sun, 10 July 2005 at 12:41 AM
Ctrl+= to go to the Face Room.
Kalypso posted Sun, 10 July 2005 at 12:51 AM Site Admin
Ctrl+z, I hate seeing the Undo selection greyed out so I just take my chances with the keyboard shortcut :)
Ben_Dover posted Sun, 10 July 2005 at 1:46 AM
Ctrl/Alt/Delete ;)
Acadia posted Sun, 10 July 2005 at 2:45 AM
I use the drop down menu.. point and click.. .method. Even in Windows I don't use key commands. Other than "CTL ALT DEL" and "CTL V"... which I just learned so I could copy my runtime paths to the Compression window in Poser, I don't know any other Window short cuts. LOL
lesbentley posted Sun, 10 July 2005 at 5:25 AM
I use the Memorize and Restore shortcuts a lot. Memorize: ALT+CTRL+A [All] ALT+CTRL+E [Element] ALT+CTRL+F [Figure] ALT+CTRL+L [Lights] ALT+CTRL+H [Camera] Restore: CTRL+A [All] CTRL+E [Element] SHIFT+CTRL+F [Figure] SHIFT+CTRL+L [Lights] SHIFT+CTRL+H [Camera]
maclean posted Sun, 10 July 2005 at 10:53 AM
Apart from the obvious ones - R, Y and U. Ctrl-M - main camera Ctrl-= - face camera Ctrl-F - front camera Ctrl-T - top camera Ctrl-E - restore element Ctrl-C/V - copy/paste Ctrl-W - close render Alt-F-H - Hier Editor Alt-F-J - Joint Editor Other than that, there aren't many usable ones. Poser hotkeys suck. Yet another thing that hasn't been changed in 10+ years. mac
onimusha posted Sun, 10 July 2005 at 2:53 PM
So either I get the fingers of a master pianist or I use the mouse. Who thought up these ridiculous key combos to do stuff you need to do constantly? Most of this stuff should be a one key shortcut...
Hawkfyr posted Sun, 10 July 2005 at 2:57 PM
Alt+f4
“The fact that no one understands you…Doesn’t make you an artist.”
