Subject: Anyone who has worked with Aiko please help
beos53 opened this issue on Jul 10, 2005 ยท 6 posts
beos53 posted Sun, 10 July 2005 at 2:59 AM
Is there a way to narrow the bridge of the nose. I have tried every dial that has anything to do with the nose. I want to move her eyes in closer, but still keep them the same distance from the nose that I have. I just need to narrow the top part of the nose. any suggestions Thank you
PoserPro 2014, Windows 7, AMD FX-6300 6 core, 8 GB ram, Nvidia GeForce GTX 750 Ti
Tashar59 posted Sun, 10 July 2005 at 4:00 AM
Try this Mag. Click/select the head. Create the magnet and use these setting to start you off. Decreaseing the Xscale of the magnet should give the effect you need. If you have moved your figure, you may need to move the mag zone to where you need it.
nukem posted Sun, 10 July 2005 at 6:44 AM
Here's an additional tip... To get a better sense of the influence area of the Mag Zone, change its display properties to Wireframe. On the PC, you can do this by selecting the Mag Zone and hitting Control-Shift-3. (Dunno what the hotkey is on the Mac.) Or you can select the Mag Zone and use the top menu: Display menu -> Element Style -> Wireframe. You can also change the Mag Zone to a solid display type (facetted or smooth shaded) then make the Mag Zone semi-transparent using the Material room.
randym77 posted Sun, 10 July 2005 at 9:28 AM
Attached Link: http://www.netherforums.com/store/index.php?main_page=product_info&cPath=12_17&products_id=6
Netherworks has a head morph pack for Aiko that includes morphs for the bridge of the nose (and lot of others). It's a great pack, nicely priced.
He also has a body morph pack for Aiko.
beos53 posted Sun, 10 July 2005 at 11:20 AM
Thank you for the information It is a great help Thanks
Xena posted Sun, 10 July 2005 at 8:22 PM
Attached Link: http://www.morphworld30.com/files.html
And for an even better way to see where your mag zone is, head over to Traveler's site and grab the TargoMag. I magnet clothing on a daily basis and this is one item I would not do without.
