Subject: A Bad Hair day - or I have a hair problem
Helen opened this issue on Feb 17, 2001 ยท 6 posts
Helen posted Sat, 17 February 2001 at 10:39 AM
I have used a magnet on the Vicky Gelhair. As you can see in the picture it shows up when rendered on the back view but not the front... It clearly overlaps the body when viewed from the back.. I just know there is going to be a simple explanation for this... I just don't happen to know what it is. Any suggestions on why this is happening and any solutions to make it show from the front as well, gratefully accepted.
Senior MarketPlace Tester
If anyone sees a mind wandering aimlessly around..... It is mine.  I want it back.
JeffH posted Sat, 17 February 2001 at 10:48 AM
Maybe the trans map renders in invisible from the front?
Helen posted Sat, 17 February 2001 at 11:03 AM
I missed it before but it doesn't actually show up pre render... Its not a big problem but one I would like to solve.. I hate mysteries..
Jaager posted Sat, 17 February 2001 at 1:16 PM
It is the normals on the hair prop. You have morphed layer that was just intended to cover the back of the head into visibility. To be visible from both sides at least one layer facing each direction is needed. Doing this will change the number of verts and thus make it a different obj. The two face utility does not just add a new set of normals, it also duplicates the polys and doubles the file size. Open the hair prop by itself. Use the grouping tool to isolate the part you wish to see from the front. export this as a prop. Import it back,and reverse the normals - make sure it is in place and save the combination as a new hair prop.
Helen posted Sat, 17 February 2001 at 9:00 PM
Thanks Jaager.. I have made a copy of this for reference.. Sometimes it takes a few re-reads for things to sink in.. I appreciate your help..
zipper0000 posted Thu, 22 February 2001 at 7:27 AM
at first i thought you couldn't see the hair from the front cuz her boobs were too big
