Subject: Big problem with IPB 1.5
Fennja opened this issue on Jul 14, 2005 ยท 8 posts
Fennja posted Thu, 14 July 2005 at 2:33 PM
Hi @ all, i have a big problem with the IPB 1.5. If I load a cr2 file, I get the message .... lines queued ... Parsing... I wait for more than one our but nothing happens. And if I close the program, I get an error message from windows. But if I load a pz2 file I will get the result after 30 seconds. Why? Can somebody help me? Hope you understand my request, I am german and my english is more than terrible :o)
RHaseltine posted Thu, 14 July 2005 at 2:38 PM
Do you have all of the figure's morphs loaded? That's the most likely cause of the problem. On the other hand if you are using poser 6 it may not like the new Poser 6 additions to the CR2.
Fennja posted Thu, 14 July 2005 at 2:42 PM
Hi RHaseltine, what do you mean with all the morphs? I want create INJ & REM for Aiko, but I have the same problem with all the other figures. I use Poser 5 and windows XP
RHaseltine posted Thu, 14 July 2005 at 2:53 PM
If you were using one of the figures that doesn't come preloaded I'd have meant did you just have the morphs used by the character loaded, or the whole lot, but with Aiko you don't get any choice. I've just loaded the base A3 and it took a couple of minutes - have you tried that (ie the !AIko 3 figure in the DAZ Aiko 3 folder, or Victoria 3 SR1/SR2/SAE from the DAZ People folder)? If that works but your saved figures don't then it isn't the amount of data, so it would seem like either a bad install (try redownloading Injection Pose Builder and reinstalling it), a problem with Poser 5 (but other people are using it OK - I assume you are loading CR2s and not trying to force it to load a compressed CRZ file), or possible a problem with the directory names in the German version of Poser 5 (that will probably stop you loading the base files too).
Fennja posted Thu, 14 July 2005 at 3:11 PM
the cr2 files from Daz People and daz Aiko folder load perfactly. I reinstall this program much times on any of my three harddisk, but its always the same. The directory names of the german poser 5 version are the same names in english version.
pakled posted Thu, 14 July 2005 at 3:56 PM
what's an IPB?(initial public buyout?)..just curious..;)
Fennja posted Thu, 14 July 2005 at 4:10 PM
IPB= Injection Pose builder :o)
RHaseltine posted Fri, 15 July 2005 at 2:59 PM
Attached Link: http://www.daz3d.com/support/contact_support.php
I just tried a quick Aiko character saved from Poser 6, with external morph targets off (not an option in Poser 5 anyway) and file compression off. It took longer to load than the base A3 but it did load. I assume poser is happy to reload your saved files? Have you actually downloaded a fresh copy, or are you using the original - it sounds unlikely that an error could be present and yet let it install, but it's possible. I think all I can suggest is contacting DAZ suppport
