bushi opened this issue on Feb 17, 2001 ยท 14 posts
bushi posted Sat, 17 February 2001 at 11:47 PM
wyrwulf posted Sat, 17 February 2001 at 11:50 PM
Jeez, I'm going to have to buy PPP just to play with what you come up with, Bushi. You are still doing amazing work.
poserpro posted Sun, 18 February 2001 at 7:32 AM
hi, bushi definitely me liking your any new py script.:)
bushi posted Sun, 18 February 2001 at 1:20 PM
Hey, thanks guys! I already have some ideas for more additions to this script so stay tuned. ;-)
duanemoody posted Mon, 19 February 2001 at 4:52 PM
Bushi: I don't have PPP and probably won't for some time, but I'd be interested in seeing a version which allows you to drop any number of head morphs into the hopper instead of just one or two, with the option to control what the total percent value is.
bushi posted Mon, 19 February 2001 at 11:57 PM
Duane - In this version, ALL the morphs on the head get changed. The next version will include an option that allows you to select which MTs are used. Now as to the total percentage control, I'm not sure about that one. Could you explain a bit more what this would do?
poserpro posted Tue, 20 February 2001 at 12:32 AM
one useful py would be to delete the wrong or redundent dials directly fom PPP withaout using external programs. TIA.
poserpro posted Tue, 20 February 2001 at 12:38 AM
I finally got rid of the problem using RD5 when I tried to spawn Morph, the morph palette will hide behide the PPP, so we have to get it back just push the desktop button and the palette will be there, then pushing the py again, everything will be normal.
bushi posted Tue, 20 February 2001 at 1:00 AM
Pro - Yes, often you can do stuff in Poser with a script minimized. I have found it a bit twitchy though. That's why I've been recommending closing a running script before doing other Poser functions. You can already delete MTs in Poser. Just open the heirarchy window, select the view for all options, select the MT you want to delete and press 'DEL'. No point in re-inventing the wheel. ;-)
poserpro posted Tue, 20 February 2001 at 10:14 AM
gee, why did I so count on py :P TIA for reminding this.
duanemoody posted Tue, 20 February 2001 at 10:56 AM
Bushi: What I was suggesting was that if you have several morphs being blended, the total of their dial values would be no greater than 1.0 to avoid grotesque-looking faces.
bushi posted Wed, 21 February 2001 at 10:42 PM
duane - OK, I see here you're going now. 'The total of the dial values ... no greater than 1.0' looks like a good idea. It would probably be best to implement it as a optional mode. I also we're talking two ranges here. That would be, all positive dials adding up to equal or less then 1.0 and all negative dials adding up to equal or greater then -1.0. Now the problem is figuring out how to make it work. :-) Thanks for the feedback and the idea.
dunga posted Thu, 22 February 2001 at 2:07 AM
wow, bushi, were you in The Creator's class when he was making the Adam and Eve? Just one thing, eyebrows sometimes are not make it... But, that's ok, it is after all the face randomizer. Guys, it is very good for a fast facial animaton, even mimic is not that good
bushi posted Fri, 23 February 2001 at 1:35 AM
dunga - Thanks! The feedback from everyone has been good so I'll get this up on the free stuff page.
