ghoyle1 opened this issue on Jul 18, 2005 · 11 posts
ghoyle1 posted Mon, 18 July 2005 at 5:51 PM
Is there any way to convert Bryce models to Poser 6? I do have Bryce 5, but I've only tried it out a few times. Guy
paper-tiger posted Mon, 18 July 2005 at 7:02 PM
Have you tried exporting as a wavefront obj, and then importing into Poser? I know transporting Poser figures to Bryce works that way, but I'm not certain if you can do it the other way 'round or not.
wheatpenny posted Mon, 18 July 2005 at 7:10 PM Site Admin
You can only export Bryce models that consist entirely of imported meshes. If it is made of Bryce primitives, or even contains any Bryce primitives then it can't be exported.
Jeff
Renderosity Senior Moderator
Hablo español
Ich spreche Deutsch
Je parle français
Mi parolas Esperanton. Ĉu vi?
dan whiteside posted Mon, 18 July 2005 at 7:11 PM
Bryce only exports terrains, rocks and imported meshes. As far as I know there's nothing else that'll do that conversion.
pakled posted Mon, 18 July 2005 at 8:21 PM
maybe trees as well, though I could be wrong..;)
zulu9812 posted Tue, 19 July 2005 at 1:38 AM
You can only export Bryce models that consist entirely of imported meshes. If it is made of Bryce primitives, or even contains any Bryce primitives then it can't be exported. Annoying that, isn't it? I swear I'm never buying another Daz upgrade on that (5.5? Pah!) until that feature is put in.
Hawkfyr posted Tue, 19 July 2005 at 2:15 AM
Bryce doesn't export Booleans either. Bryce Booleans are not true booleans in that,they really don't modify the mesh. It just tells Bryce's render engine "Dont render this"... Tom
“The fact that no one understands you…Doesn’t make you an artist.”
dan whiteside posted Tue, 19 July 2005 at 7:47 AM
Pakled - no tree export Tom - just because Bryce does parametric booleans doesn't make it less true then a mesh boolean. In fact you're more likely to get a "true" boolean out of a parametric object then a fixed mesh.
Hawkfyr posted Tue, 19 July 2005 at 9:37 AM
pakled posted Tue, 19 July 2005 at 11:58 AM
ah..well..;) I tend to import everything into Bryce, so I claim ignernt..;) the only thing I export out of Bryce are pictures for Poser backgrounds..;) good to know, tho..;)
Boni posted Tue, 19 July 2005 at 2:56 PM
Just to let you know I've heard that there may be true exporability (and poser/texture importability) with the next incarnation of Bryce. Remember, DAZ hasn't had Bryce that long, give them a chance to do it right folks. :) Bryce originally was never intended to be a modeler, only an environment creator. The users stretched the program to do things that were not originally thought to be part of the program ... they did the same with Poser throughout the years. We as users have tested the limits and sometimes that creates larger challenges to the creators. I think both programs have evolved wonderfully over the last decade plus. We are all in this together. Boni
Boni
