Francemi opened this issue on Jul 19, 2005 ยท 17 posts
Francemi posted Tue, 19 July 2005 at 2:52 PM
Since I didn't use Poser 5 since I have Poser 6, I would like to uninstall it. I go to Add/Remove Programs and it doesn't show up in the list! Looked into Start Menu/All Programs and it's not there either. How can I uninstall it without uninstalling Poser 6? Thanks. France
France, Proud Owner of
KCTC Freebies
xantor posted Tue, 19 July 2005 at 3:09 PM
If you don`t have any content that you use with poser 6 in the poser 5 drawer, then it is okay to just delete the whole poser 5 drawer.
Francemi posted Tue, 19 July 2005 at 3:45 PM
You mean it is not in the Registry?
KCTC Freebies
wyrwulf posted Tue, 19 July 2005 at 4:21 PM
On installation, Poser 6 took over anything that an earlier version might have put in the registry.
soul_survivor posted Tue, 19 July 2005 at 4:54 PM
Francemi posted Tue, 19 July 2005 at 5:39 PM
No, I don't. I only have that for Poser 6. Poser 5 is not even showing in the Start Menu anymore. If I want to run Poser 5, I have to go to its folder and double-click on Poser.exe. I had a link in my Quick Launch bar for Poser 5 but now if I use it, it launches Poser 6 instead. And Poser 6 is not installed in the same folder as Poser 5. I have both of them outside of Program Files. France
KCTC Freebies
Francemi posted Tue, 19 July 2005 at 5:40 PM
Oops, I didn't see your reply wyrwulf. So then it is really okay to just remove Poser 5 folder?
KCTC Freebies
wyrwulf posted Tue, 19 July 2005 at 5:48 PM
As long as you aren't going to want anything in the P5 folder, just delete it.
Francemi posted Tue, 19 July 2005 at 6:09 PM
Thank you all of you. I made sure to retrieve all I could need from that folder. Now I will remove it and make some room for Poser stuff. ;o) Of course I could always re-install Poser 5 if I ever want to as I have the CD for both P5 and P6 but it is useless on my computer now. I much prefer Poser 6!
KCTC Freebies
xantor posted Tue, 19 July 2005 at 6:47 PM
If you are really bothered about the registry you could use regedit and look for poser 5 and delete all the poser 5 stuff you find, there usually is only 3 or 4 things.
Francemi posted Tue, 19 July 2005 at 7:20 PM
Nah... It unnerves me to play with Regedit ;o) I deleted Poser 5 folder and I guess it will have to do. Thanks!
KCTC Freebies
Fazzel posted Tue, 19 July 2005 at 9:43 PM
Yep, just go to the Poser 5 folder and hit delete.
Ardiva posted Tue, 19 July 2005 at 10:12 PM
Attached Link: http://www.sofotex.com/downloads/d7528.html
France, I don't like to manually tinker with regedit either. So I found this really great program that does it for you. I use it alot! :) Automatically finds reg problems and then you can delete them safely. http://www.sofotex.com/downloads/d7528.htmlFrancemi posted Tue, 19 July 2005 at 10:47 PM
Thank you Ardiva, I will get it! ;o)
KCTC Freebies
Ardiva posted Tue, 19 July 2005 at 10:51 PM
Francemi posted Wed, 20 July 2005 at 11:24 AM
I installed and ran it last night... Found 98 errors and fixed them! Thanks a lot!
KCTC Freebies
Ardiva posted Wed, 20 July 2005 at 12:21 PM
