Rod Madic opened this issue on Feb 19, 2001 ยท 2 posts
Rod Madic posted Mon, 19 February 2001 at 4:16 AM
HI,can you export Poser 4 characters into Max 3.1 in 3DS format? Are there any problems when transporting files? Thanks for any help.
genetic posted Mon, 19 February 2001 at 6:48 PM
Actually i've encountered problems with the export tool in Poser 4. I've found that if you export them using alot of Poser's objects and morphs as a 3DS file, 3D Studio will read it as an improper file format. For some reason,however, i can export a figure in a pose really good but if they aren't wearing any clothes. The only solutions I have found is one that might not be right for you. But if you have true space, there is a plug-in you can purchase at http://www.gothicsystems.bizland.com/news.html. The name of the plug-in is object man. It will import several different file formats (including quake files) and export them in to many other ones including 3DS. I've been able to export the files as an alias object file and resave it as a 3DS file that works for 3D Studio Max. Unfortunatley you can't export the animation in a sequence that is saved into the file. But at least you can get the model in there.
