Forum: Photoshop
Subject: Need help...
jartz opened this issue on Jul 26, 2005 · 8 posts
jartz posted Tue, 26 July 2005 at 12:16 AM
Is there a way that I can make brushes for use in Photoshop? Would there happen to be a tutorial or some sort that can actually let me achieve this?
I'm trying to make some brushed that I can create myself and save as my own brushes.
How can I do this?
Thanks,
jbWStar
____________________________________________________________________________________________________________________________
Asus N50-600 - Intel Core i5-8400 CPU @ 2.80GHz · Windows 10 Home/11 upgrade 64-bit · 16GB DDR4 RAM · 1TB SSD and 1TB HDD; Graphics: NVIDIA Geforce GTX 1060 - 6GB GDDR5 VRAM; Software: Poser Pro 11x
Sans2012 posted Tue, 26 July 2005 at 9:08 AM
Make a selection. Then, "create brush" with the selection;)
I never intended to make art.
bonestructure posted Wed, 27 July 2005 at 12:52 AM
There should be an entire explanation of how to make brushes in the help files ort user manual of whatever that installs with Photoshop. For some reason, when it comes to Photoshop people rarely read those. I guess because the software has been around so long.
Sans2012 posted Wed, 27 July 2005 at 4:00 AM
I think there is an explination in help. What version you using? Did you have any luck making your brush?
jartz posted Wed, 27 July 2005 at 10:43 PM
I use version 8. I've been so fond of how other artists makes their own brushes and utilizes them as their own set.
I think I got the hang of it. I think what I did was 'save' myself a brush pattern, select the item that I want to make the brush out of [e. g.: a lip texture I made for V3], select 'Define brush' in the 'Edit' menu, name it and it's saved.
What I didn't know of is that you have to save your own brush you make. What I did originally was that I defined the brush, and put it in one of the presets. That's when I was referring to the online help menu.
However, I think I did alright.
The reason I made this post was: I just wanted some information on how to make brushes of my own creations. Since I'm using Poser and making a texture for V3, I've been quite comfortable with Corel PhotoPaint 11 for a while, that it's nearly impossible for me to get the feel with PhotoShop. I cannot say that I have no expertise in using it [the basics], it just some of the complex uses of it.
Sometimes I feel like a nut.
I think I got the hang of it. I saved myself a brush preset and define the brush I made -- whatever that is.
Thanks for the replies. They're most helpful.
I welcome to more input.
--jbWStar--
Sans2012 posted Thu, 28 July 2005 at 12:56 AM
It seems you know what your doing now;) Keep up the good work!
retrocity posted Thu, 28 July 2005 at 6:35 AM
don't forget to take all the brushes you've made and create a "brush set" so you don't lose them. remember, if that "can't" be reloaded, they "can" be lost! :) retrocity
Sans2012 posted Thu, 28 July 2005 at 9:06 AM
Ah! Good advice there. I'm a sucker! Pick me! Pick me:)
