Subject: Editing a Poser Model
dstephany opened this issue on Jul 26, 2005 ยท 6 posts
dstephany posted Tue, 26 July 2005 at 11:05 AM
I have a bike, which I got for free and I'd like to remove the basket and move the reflector from below the wheel to above the wheel. I'm posting pics so everyone can see what I mean. Would anyone like to help me make this change, if its possible ? I'd be willing to compensate you for your time. Please either email me direct at rrtoadway@yahoo.com or post your responses here. Thanks, Doug Here is where you can find the model, http://lab108.x0.com/lab108/vehicle.html
dstephany posted Tue, 26 July 2005 at 11:06 AM
This is what I would like to change it to look like, again if possible
Jules53757 posted Tue, 26 July 2005 at 1:08 PM
With this model it's not so easy. The basket is not seperate like the saddle, so you can't unhide it. The only way is to use an other model or you have to go to an other 3D-software to make the neccessary changes in the obj-file.
Ulli
xantor posted Tue, 26 July 2005 at 2:34 PM
If you have uvmapper pro. To remove the basket, load the bike into uvmapper then select by material and select the three parts with the word basket in while holding down the shift key then press delete it will ask if you are sure click on yes and save the object without the normals and that is it. I tested this and it does work.
raven posted Tue, 26 July 2005 at 3:50 PM
If the basket has a material, then just make it transparent in Poser. Saves excess fiddling in a modeller :)
bjbrown posted Tue, 26 July 2005 at 4:59 PM
If the basket doesn't have a material, you can make the material for it in Poser.
