wotdoin opened this issue on Jul 26, 2005 ยท 4 posts
wotdoin posted Tue, 26 July 2005 at 2:47 PM
Hi, I need to know how to make REM poses for clothes. I have used the Mat pose edit 3 to make the inj pose files, do I just use that program again and white everything out and use as a REM? I have never tried to do this and so don't know if there is another program or what to use. Thanks so much,
Debbie
SWAMP posted Tue, 26 July 2005 at 3:40 PM
Hi Debbie, Yea you got it.... Just open one of the Mat/pose files and set everything to white and click on the "No Mat" button. Be sure to do a "Save As" with a new name so you don't overwrite the original file. Chuck
wotdoin posted Tue, 26 July 2005 at 9:46 PM
Thanks a bunch, I didn't want to do it the wrong way and then have to do it over.
EnglishBob posted Wed, 27 July 2005 at 4:15 AM
If your poses are applying and removing textures and materials, it's best not to name them INJ and REM - those terms are used for poses which load or unload morphs on figures like V3 and M3. People might be confused by applying an INJ which didn't change their character's shape. Most MAT pose sets I've seen don't bother with an "all white" MAT, although it can be useful occasionally. You would generally just apply a new MAT to the item - although you need to take care that everything necessary has been reset. For instance, you should explicitly set transparency off in MATs which don't use it, in case your MAT is replacing one that had transparency on. On the other hand, if I misunderstood your question, just ignore me. :)
