JackStr8 opened this issue on Jul 27, 2005 ยท 28 posts
JackStr8 posted Wed, 27 July 2005 at 10:20 PM
Sans2012 posted Thu, 28 July 2005 at 1:02 AM
Maybe your Ram could be the problem? Try removing sticks to see if anything changes;)
I never intended to make art.
Dann-O posted Thu, 28 July 2005 at 4:42 AM
"256 rpp, no lights, soft shadows, blurry reflections." No wonder. Why would anyone render at 256 rpp. that is insane you just love to wait long periods of time for your picture to be done. Let alone soft shadows and blurry reflections. You need to manage your resources more effectivly. I guess you get a lesson in that when you are an old timer like me and at one time rendered on a 6800 series processor in Bryce 1.0. Go down to 32 rpp you probably won't be able to tell the difference. If you get rid of the soft shadows and blurry reflections then you can go down to 4rpp.
The wit of a misplaced ex-patriot.
I cheated on my metaphysics exam by looking into the soul of the
person next to me.
ysvry posted Thu, 28 July 2005 at 5:07 AM
why is 256 rpp included then?
JackStr8 posted Thu, 28 July 2005 at 6:58 AM
I have the same RAM I had before I initially installed Bryce 5.5 and didn't have this problem--Bryce 5 ran like a dream. However, if I render at 36RPP or higher it crashes--I was using 256 to push the software. It didn't take as long to render as you might think--I got a few renders out of it before I tweaked the render settings and BOOM. Interesting, though--if you look at the error message the problem seems to be caused by the way Bryce 5.5 is doing the calculations, not my system. Then again, I could be wrong about that. Anyone else get anything like this? Any ideas?
Message edited on: 07/28/2005 06:59
cornelp posted Thu, 28 July 2005 at 7:14 AM
Even if your system ran fine before with the same RAM, does not mean the RAM is not bad. RAM does go bad from time to time. I would check on that. If U uninstalled, updated, upgraded, did everything U can think of, then the next step would be hardware. Just remove or change the RAM temporarily and see what happens. I get those errors sometimes, and its not cause of the system, but cause of the way I made the render, lights and textures. One time I had a problem where the bryce 5.5 would not render with this one texture for the heck of it. Once I removed that texture and replaced it with a similar one, bam, no more crash in THAT scenery. Change your RAM Temporarily, and see what happens.
shinyary2 posted Thu, 28 July 2005 at 8:57 AM
I've rendered images on 256 RPP before in Bryce5 and no crashes. I have 1GB RAM. I think it's insane that you should have crashes with such a simple scene; the more I hear about it, the more Bryce5.5 disgusts me. I'm glad I didn't waste my money on it.
JackStr8 posted Thu, 28 July 2005 at 8:52 PM
That's what's really getting to me. The scene is set at 256RPP, but there are no lights. And whatever issue is causing Bryce 5.5 to crash has "migrated" over to Bryce 5!I'll try the suggestions about changing out the RAM. Hmph. Maybe 5.5 replaced a DLL that Bryce 5 was using with a sucky one?
Message edited on: 07/28/2005 20:53
Sans2012 posted Fri, 29 July 2005 at 12:37 AM
I have problems with Ctrl+Z! When I go back two many times or too fast, oops! There it all goes. Damn those coders!
LostinSpaceman posted Fri, 29 July 2005 at 3:41 PM
Ummm... LOL ... umm I'm embarassed to ask this having been using Bryce 4 for over 6 years but what the heck is RPP?
Sans2012 posted Fri, 29 July 2005 at 4:15 PM
rays per pixel :)
catlin_mc posted Sun, 31 July 2005 at 8:43 PM
I've been getting this kind of thing too and I know how you feel about kicking a little program's ass. lol 8) I don't think it's a matter of what ram you use or anything else related to what components are in your box. All other 3D software I use on the same machine works fine so it's definately a glitch with 5.5. I just hope that when DAZ get Br6 out they'll give a discount to all us beta testers who had so many problems with Br5.5. Catlin
LostinSpaceman posted Sun, 31 July 2005 at 9:25 PM
What is the difference in ray's per pixel as opposed to DPI, dot's per inch? Sounds like something I should learn about.
JackStr8 posted Mon, 01 August 2005 at 12:03 PM
Rays per pixel refers to the number of rays Bryce uses when rendering. Dots per inch is a printing term. You've probably heard that 300 DPI is the minimum recommended image resolution for printing.
LostinSpaceman posted Mon, 01 August 2005 at 7:28 PM
Hopefully my last stupid question: Where do you set RPP in Bryce? Version 4 or 5 only.
JackStr8 posted Mon, 01 August 2005 at 10:44 PM
LostinSpaceman posted Mon, 01 August 2005 at 11:30 PM
The one drop down arrow I've never clicked on of course! LOL! So much to learn so few hours in the day.
Sans2012 posted Tue, 02 August 2005 at 1:55 AM
Now you will have plenty of hours in the day, rendering that is;)
jelisa posted Tue, 02 August 2005 at 12:43 PM
If the problem has "migrated to Bryce 5" I'd be more likely to look at a hardware/RAM problem if the two versions are on the same computer. Especially since the two programs are independent of each other.
JackStr8 posted Tue, 02 August 2005 at 5:41 PM
Thanks for the input and suggestions. Much appreciated. The two programs are TRULY independent of each other? They don't share any .DLL files--possibly one that the 5.5 version replaced?
jelisa posted Tue, 02 August 2005 at 6:14 PM
Not that I'm aware of if you installed them to separate directories. I can check for sure though, may take a few days to get a reply.
JackStr8 posted Tue, 02 August 2005 at 10:13 PM
Thank you. Much appreciated! :)
LostinSpaceman posted Tue, 02 August 2005 at 10:48 PM
Oh I can leave Bryce rendering for days and day's on my 1 ghz dinosaur while I spend all my time in my 1.9 ghz dinosaur with Poser 6. ;)
JackStr8 posted Wed, 03 August 2005 at 6:54 AM
LostinSpaceman posted Wed, 03 August 2005 at 4:16 PM
Is that a human figure exported from Poser that I see? I need to learn more about getting the skin tone to look right on imports like that. Mine always look washed out in Bryce.
catlin_mc posted Sat, 06 August 2005 at 3:45 PM
The render time is why I've got a 2.4GHz machine which is for renders only which means I still have my 64 bit machine for the hard work, Poser. lol 8) Catlin
JackStr8 posted Sat, 06 August 2005 at 5:58 PM
Mizrael, there are tutorials on using Poser skin textures in Bryce, but if your skin tones are looking washed out, check the settings in the Materials Lab. The settings for your lights factor into this issue--you have to get Diffusion, Ambience, and Specularity to work with the lights, and so these three may need to be adjusted. Try lowering the Diffusion in increments of 10, drop Ambience to under 10, and Specularity to 5 or less.
LostinSpaceman posted Sat, 06 August 2005 at 6:19 PM
Thanks again Jack! I'll look for those tutorials too.
