Forum: Vue
Subject: Cornucopia trees, interesting :)
silverblade33 opened this issue on Jul 31, 2005 ยท 18 posts
silverblade33 posted Sun, 31 July 2005 at 9:16 AM
Ok, I made a mistake and downloaded the VUe5 trees, and servers crashes as I was gonan re download, doh, so these may NOT be as good as should be as I use Infinite. large conical pine
silverblade33 posted Sun, 31 July 2005 at 9:17 AM
prehistorical tree birch tree
silverblade33 posted Sun, 31 July 2005 at 9:23 AM
distant pine trees
Mazak posted Sun, 31 July 2005 at 9:41 AM
Looks good; The trees have much detail :) Mazak
Google+ Bodo Nittel
randym77 posted Sun, 31 July 2005 at 10:34 AM
The distant pine trees look really good in your picture. I wasn't impressed with them in the store. I guess showing distant trees in closeup isn't a good idea. ;-)
martial posted Sun, 31 July 2005 at 3:51 PM Online Now!
The white automn birch seems nice But when i take a closer look to the leaves they dont seems to be birch leaves(look likes maples ones).I check in a book ...but,please,if someone using VUE have more knowledge about trees take a look and see it.Thanks
martial posted Sun, 31 July 2005 at 4:35 PM Online Now!
See one closer render
dlk30341 posted Sun, 31 July 2005 at 5:32 PM
Those leaves don't look very good. Not sure if it's because of the render method, but I see alot of artifacts around the leaves.
timoteo1 posted Mon, 01 August 2005 at 1:36 AM
I think it must be render method. I am getting some of these trees and will try various rendering settings and see if I can't eliminate some of the noise.
martial posted Mon, 01 August 2005 at 4:26 AM Online Now!
I know i can make a better render ,I just want to show the leaves,which are not birch leaves according the common birch leaves i have seen in a book and around there.If someone can confirm this,may be Eon will modify it and everybody will have a good birch tree.The trunk seems good and well textured
randym77 posted Mon, 01 August 2005 at 6:10 AM
You're right. Those don't look like birch leaves. Unless Canada has a birch leaf on their flag. ;-)
iloco posted Mon, 01 August 2005 at 7:20 AM
I have white birch in my backyard and those leaves definitly don't look like a birch leaf. Look more like a maple leaf. :o)
ïÏøçö
dlk30341 posted Mon, 01 August 2005 at 8:45 AM
Attached Link: http://www.marshhawkmeadowgallery.com/WHITE%20BIRCH%20LEAF.html
Here's a pic of a white birch leaf....
Ms_Outlaw posted Mon, 01 August 2005 at 4:58 PM
Yeah the leaf thing has been reported. Another mistake by someone. Hopefully they will fix that to.
martial posted Mon, 01 August 2005 at 6:09 PM Online Now!
Thanks everyone.Hope Eon correct this soon!
nanotyrannus posted Mon, 01 August 2005 at 6:44 PM
Actually this isn't even a new bug, it's been there since eon never bothered to actually change the leaf texture when they put together their bonus plant pack for Vue 4 Pro, so probably what happened was when cornucopia got ahold of it they just assumed the leaf was correct (eon used the maple tree as the base for the springtime birch and forgot to change the texture to a new leaf shape). Just one of many little details that you don't even notice till you get close up (which I usually don't for Vue trees anyway, they may imply that they are highly detailed but for close up plants I've ended up resorting to xfrog trees or some of the really nice freebie ones floating around). Anyway, just a little history on an annoying problem :)
jc posted Mon, 01 August 2005 at 11:10 PM
Thanks nanotyrannus & all - good to know.
skytimelapse posted Tue, 02 August 2005 at 11:05 PM
silverblade, did you get those distant pines in an ecosystem? Cant get that to work in V5I. Tried all the new trees...
