Subject: New Crashing Issue
whoah opened this issue on Jul 31, 2005 ยท 5 posts
whoah posted Sun, 31 July 2005 at 9:36 PM
Hello, Today, quite at random, poser 6 has decided to start crashing without warning when I click on anything that opens an explorer window (save as, open, run python script...) It just immediately closes. It's very odd. Anyone know how to correct this? I have re-installed the program and it still occurs, suggesting a different problem.
destro75 posted Sun, 31 July 2005 at 10:22 PM
Hmm, sounds odd. Do you recall exactly what it was you did between the time it last worked, and the first time the crash happened? Maybe with a list of events leading from working to not we can find a solution.
whoah posted Sun, 31 July 2005 at 10:48 PM
I knocked the hardware acceleration down one notch, and it worked perfectly. Interesting...
Fazzel posted Mon, 01 August 2005 at 11:01 AM
Have you updated your video card software? If so maybe that is the problem. If not, maybe you do need to update it.
The-Preacher posted Tue, 02 August 2005 at 2:17 AM
Can be anything... really... If hardware acceleretion fixed it, probably you could make an update... but maybe the card simply overheated... My poser 6 did fancy things yesterday btw... when i tried to run python 'delete all lights', my whole scene turned grey, and stayed grey... I had to close, and reopen... revert would not work.. I figure poser is a quite sensitive program, dependng very much on the platform and harware you use it with.. Many of you say you use athlons and 'round 1 gigs of memory... I have the same, and a pci-e card... still I have very-very long renders and unexpected crashes...
