Subject: common prblem im sure...
icandigit opened this issue on Aug 02, 2005 ยท 11 posts
icandigit posted Tue, 02 August 2005 at 8:19 PM
For some unknown reason, when I tried to load my Poser 3, I got a "not enough memory to run Poser" error... What's the deal with that? thanks :D
Tunesy posted Tue, 02 August 2005 at 8:24 PM
...at the risk of sounding trite I'd guess you don't have enough memory ;) Is your comp as old as P3? )
mateo_sancarlos posted Tue, 02 August 2005 at 9:31 PM
P3 didn't need much memory. It's probably a question of a new OS being incompatible with the obsolete app.
icandigit posted Tue, 02 August 2005 at 10:44 PM
i can assure you, it is not my operating system, or that i dont have enough memory... i have been using poser for quite some time now, dont know what caused this...
xantor posted Tue, 02 August 2005 at 10:49 PM
I had a similar problem with poser 4 on my computer, you could try reinstalling it but uninstall first so that none of the old data is left behind because it might have got corrupted some way.
icandigit posted Wed, 03 August 2005 at 12:19 AM
had to reset paging file to get it to work... thanks anyway tho guys :D
xantor posted Wed, 03 August 2005 at 11:06 AM
You would be much better off with poser 4, it can do much more than poser 3 can.
icandigit posted Wed, 03 August 2005 at 11:21 AM
i have this italian disease you see... "myfundsarelow" :P
xantor posted Wed, 03 August 2005 at 12:58 PM
That was what I thought, but 4 is much better.
icandigit posted Wed, 03 August 2005 at 3:11 PM
honestly, ive gotten so used to using poser 3, and that it still does serve me very well, i havent the need for anything better... daz studio was a HUGE boost to what i can do and use, but i still havent seen the need to get a better a version... ( ( ), as there is always a but somewhere, the reason i needed poser this time was because i wanted to start making poseable models, and not until now did i have a need to upgrade... thanks...
EnglishBob posted Thu, 04 August 2005 at 4:12 AM
The problem is actually too much memory. When Poser 3 was released, 1GB RAM was an unimaginable amount - nowadays it's commonplace. Poser 4 had the same problem to begin with, but a patch was released to fix it. Poser 3 was never fixed. Sorry. :( If you do upgrade to 4, you won't look back.
