Subject: needing some Walk Designer help
zulu9812 opened this issue on Aug 05, 2005 ยท 9 posts
zulu9812 posted Fri, 05 August 2005 at 12:27 PM
I made a 15-frame run animation using the P6 walk designer. Run, Shuffle and Sneak were all set to 60%, with the character walking In Place. There is a slight delay between the 15th and 1st frame, which results in the transition being jerky. Obviously, some tweening will sort this but that kind of defeats the purpose of computer animation. I've also noticed that the Walk Designer always does this. Is there anything I can do to make the walk designer work better?
almostfm posted Fri, 05 August 2005 at 12:39 PM
Is the 15th frame identical to the first? If it is, you can get a "jerk" in the animation, because it's essentially showing frame 1 twice in a row (at frame 15 and again at 16)
zulu9812 posted Fri, 05 August 2005 at 12:44 PM
Thanks for the reply. The 15th frame might be the same as the 1st - I have Loop Interpolation turned on. I was under the impression that makes the last frame lead into the first - but does it actually make both frames the same?
xantor posted Fri, 05 August 2005 at 2:05 PM
Try making the animation one less frame that should fix it. It isnt caused by loop interpolation being on, it is just something that happens when making walk cycles, it isnt really a bug either.
zulu9812 posted Fri, 05 August 2005 at 2:13 PM
Try making the animation one less frame that should fix it. Do you mean use the Retime Animation function?
mateo_sancarlos posted Fri, 05 August 2005 at 4:47 PM
Save a range of frames, excluding the last frame.
shedofjoy posted Fri, 05 August 2005 at 5:48 PM
why dont you set the walk cycle to repeat twice and just use the first walk cycle? this sometimes helps or copy the first frame to the 16th frame and adjust the 15th so that runs smoother to the 16th, then delete the 16th...
Getting old and still making "art" without soiling myself, now that's success.
xantor posted Fri, 05 August 2005 at 6:02 PM
Dont use the retime function just make the animation one less frame by typing the number into the animation frames part.
BastBlack posted Fri, 05 August 2005 at 9:14 PM
I spy a Civ fan! ;) bB <-- who has lost many days on Civ. ;)
